i need some help swapping an si motor into my dx
Old Mar 12, 2003 | 08:26 PM
88rexdxa6ed's Avatar
Default i need some help swapping an si motor into my dx
i got a straight 88 dx and a beat 90 si with a killer built motor, how hard is it to install the si motor in my dx? i'm a vw guy and don't know to much about these honda's yet. if anybody is local i could pay them to show me how, i will do all the install i would just need help wiring it up.
Old Mar 12, 2003 | 08:33 PM
darkracer's Avatar
Default Re: i need some help swapping an si motor into my dx (88rexdx)
the motor drops right into the car, it has the same mounts. IMO i think you should swap to the Si suspension, change the whole front assembly, and the entire back assembly too. when you do that you have to use the Si axles because the Si hub side of the axle is bigger than the DX hub side of the axle and the car. You would want to run the bigger axles so you don't have to worry about snapping them. i have to do the same thing with my Dx because i just picked up a T25 turbo and i am swapping to a 92 Si motor. it's worth it, good luck man.
Old Mar 12, 2003 | 08:34 PM
matt j's Avatar
they bolt right in but you have to rewire your engine harness, do a search for mpfi swap and you will get a bunch of info
Old Mar 12, 2003 | 08:55 PM
Default Re: i need some help swapping an si motor into my dx (mattED6)
well i'm probably gonna use the dx axles because there brand new and the si axels click like a son of a bitch. can i use the si dash? and is the si tranny geared diferent than the dx?
Old Mar 12, 2003 | 08:58 PM
jisu009's Avatar
I can help you...I live in Kirkland WA...hit me um with an IM...I am a VW guy too..but I have a 90 HB w/ B16 now...i got your back
Old Mar 12, 2003 | 09:03 PM
enigma94's Avatar
take his advice on the axels because you dont want to snap them while driving or racing, if they snap could cause other damages, safer to replace them now.
Louie B.'s Avatar
The mpfi swap is the only thing to really worry about, use everything off of the SI engine... if you want to use the si axles, you'll need the Si hubs and knuckles, if you want to make it easy on yourself, you can use the dx axles and leave your hubs and knuckles on there.
You'll also want the tranny: the Si tranny has the same 1st-5th as your DX, but the final drive is lower. If you do use your 88DX trans, you will need to use your 88 flywheel, clutch, and pressure plate. The 88 tranny has a 21 spline input shaft, the 90 has 20 splines, so the clutch disk won't fit. use the si's tranny, clutch, PP, and flywheel and you'll be fine.
the best place to find out about the DX to Si wiring changes is here:
http://hybrid2.honda-perf.org/tech/4gdxtozc.html
the ZC and the Si have the same wiring.
I'm not quite local, but I'm not too far off (1hr south of Portland) the problem is, I'm having a few problems with my Si swap right now, so there's no way I could get up there right now. I know there's a few guys up your way that could help, we just had a NW H-T meet in Seatle and I met a few of them. Most of them seem to be driving EG's or EK's though.
[Modified by thumpu77, 10:05 PM 3/12/2003]
Default Re: i need some help swapping an si motor into my dx (jisu009)
hey jeremy, do you have aol instant messenger? this honda tech won't let me im or are you ever on vortex?
Old Mar 12, 2003 | 09:05 PM
jisu009's Avatar
on the tex all the time..jisu009@attbi.com is my tex name..hit me up... i am there now
Old Mar 12, 2003 | 09:15 PM
hit me up on the tex, my screen name is screamin8vgti. you can find me on the golf 1 classifeid
Old Mar 13, 2003 | 12:35 PM
anymore pointers?
Old Mar 13, 2003 | 12:55 PM
AbaZ's Avatar
The DX/SI hubs are the same, and the axles are almost identicle, So you dont have to change those out. Maybe you are getting cunfused about the HF hubs/ and HF axles.
Snapping axles takes alot more than just a stock A6, it takes some serious HP, and some hard launchs..
The wiring swap is pretty easy, their are lots of write ups on how to do the dpfi-mpfi swap.
Since you are local, I can do the Swap for you if you like...
285 for R&R motor (includes fluids), and 85 for DPFI-MPFI Swap (includes wiring/resistor box), I can get it done in 1 day no problem. I also have an SI ECU for 40 bucks..
(we are certified techs btw..)
IM/PM me if you are interested..
Jeff Frank
GsrTurboCRX88
Aug 22, 2006 07:59 PM
sgi
Jan 21, 2003 11:39 AM
Red_Si
12
Sep 4, 2002 12:07 PM
simike
Aug 13, 2002 02:50 PM
ysrhatch
Feb 8, 2002 07:03 PM
