Antenna makes horrible grinding noise and does not move in '90 Integra
Old Mar 12, 2003 | 08:12 PM
rody084's Avatar
Default Antenna makes horrible grinding noise and does not move in '90 Integra *SEARCHED*
I have a power antenna on my 1990 Integra GS and when i first bought the car (used a week ago) the antenna would not move at all, it would just make a HORRIBLE grinding noise and it would not move. I tried dropping some WD-40 on it and making sure that it gets inbetween the separate parts of the antenna and that it is all lubed up. This helped the problem, now the antenna will go all the way up from the bottom position (but still makes the horrible noise for a second after it finishes fully extending) on the way down, at about 8" from reaching the bottom, it gets stuck and makes the horrible grinding noise.
Do you think I should keep dropping WD-40 on it till it fully moves or is there something else that I can do to it?
[Modified by rody084, 5:15 AM 3/13/2003]
Old Mar 13, 2003 | 06:55 AM
rody084's Avatar
Default Re: Antenna makes horrible grinding noise and does not move in '90 Integra *SEARCHED* (rody084)
anyone? any other ideas?
wxy117
Mar 24, 2008 10:26 PM
Kamikaze
Jun 1, 2006 11:46 AM
krings
Feb 17, 2003 12:16 PM
