got the vss, but will my speedo be correct?? Cause of different tire sizes.
Old Mar 12, 2003 | 07:22 PM
PhatHardy's Avatar
Default got the vss, but will my speedo be correct?? Cause of different tire sizes.
Ok, I got an electronic VSS with my b16 swap, I don't know which honda it came off of, I got it added extra. But i'm wondering, are all the electronic vss's the same, like as far as the gear ratio's, like when i look up what tire size i should have, should it be the same as the 92+civic's and 94+integra's?? Right now i got Del sol rims and tires, and i seem to be pretty acurate, So i'm thinking when i get my rims and tires i should get the ones that would go on a 92 civic instead of a 90 crx, just a guess, see what you guys think.
Old Mar 12, 2003 | 09:40 PM
Cvic90's Avatar
Default Re: got the vss, but will my speedo be correct?? Cause of different tire sizes. (PhatHardy)
All B-series VSS are the same. If you use the Teg sizing it will be correct. 195-60-14'zI've got 205-50-15'z and it's right. it starts to change if you go any bigger. My 205-40-17'z are 5-7 mph higher when speedy says 70 mph.
Old Mar 13, 2003 | 02:11 AM
PhatHardy's Avatar
Default Re: got the vss, but will my speedo be correct?? Cause of different tire sizes. (Cvic90)
cool, what about the D series VSS's don't those work in the b series trannies too?? Are those the same?? So when i look up my tire sizes and stuff i should look something up for an integra??
Artikgrau325is
Jun 8, 2009 05:36 PM
PinoyDelS0l
Jan 29, 2009 09:25 AM
crx2ner
Aug 27, 2006 07:20 PM
majeed11
May 29, 2003 08:41 PM
dclub01
May 24, 2003 07:45 PM
