axles aren't going in! help
Old Mar 12, 2003 | 06:56 PM
EFLaosGirl's Avatar
Default axles aren't going in! help
I am swapping a b18c1 into my ef. The frame is preventing the axles from going in. What should I do? Any ideas that might help would be great.
thanx
[Modified by EFLaosGirl, 3:56 AM 3/13/2003]
Old Mar 12, 2003 | 06:58 PM
tek_civic's Avatar
Default Re: axles aren't going in! help (EFLaosGirl)
sorry not too familiar with crxs but id like to say that car will rip! id like to see it run.
Old Mar 12, 2003 | 07:01 PM
EFLaosGirl's Avatar
Default Re: axles aren't going in! help (tek_civic)
its not a crx. its a 91 hatch si
Old Mar 12, 2003 | 07:07 PM
Malgerus's Avatar
There is no way the frame should prevent yuo from using those axles. Can you explain your problem in more detail and provide pics? Are you using the right axles? Cable tranny? Which intermediate shaft?
Old Mar 12, 2003 | 07:18 PM
EFLaosGirl's Avatar
Default Re: axles aren't going in! help (Mr. S)
ok the motor is a 94 gsr, and i am using a 91 ls tranny. and the problem is coming from the passenger side, where the lower control arm bolts into the frame. the axle is slightly going in but u can clearly see that is hitting the frame. and inorder for the axle to go all the way throgh you would have to hammer it in, and even when its all the way through, the inner joint is still resting on the frame. the car has been in an accident. and i know the frame is bent. is there any way around this????
Old Mar 12, 2003 | 07:38 PM
Malgerus's Avatar
Hmm. Unless you can get the frame straightened out, I don't think there's much else you can do.
Old Mar 12, 2003 | 07:40 PM
RenoRacing's Avatar
ummm. wow, it must be really bent, my frame is nowhere near my axles, cut that biznitch! lol
Old Mar 12, 2003 | 07:43 PM
EFLaosGirl's Avatar
couldn't i just bang that part of my frame to try to make room for the inner boot? Or would i just make matters worse?
Old Mar 12, 2003 | 07:45 PM
EFLaosGirl's Avatar
yeah, it should rip! The question at hand is how in the world am i going to get this to work without having to pull the motor back out and drop it into another car.
Old Mar 12, 2003 | 08:10 PM
incubus's Avatar
i know that this is off topic of the subject, but you should probably pick up another tranny. An LS tranny is too widely geared, it is going to slow you down a lot.
Old Mar 12, 2003 | 08:21 PM
Danger's Avatar
might as well try it since the frame is already messed up . i dunno how it is gonna handle though .
Old Mar 12, 2003 | 08:25 PM
Malgerus's Avatar
Default Re: axles aren't going in! help (JonnyDanger)
Is it hitting the place where the LCA bolts in? You can maybe bang the mounting location in a little, but not too much.
Old Mar 12, 2003 | 08:28 PM
pokemon's Avatar
Well if it messes up the handling, just race in straight lines. As for banging in the frame I don't see why not if you don't then you will never know if it would have worked eh? Just keep in my how much the mounts might flex and if it isn't banged in enough the axle will still hit it so do it enough to prevent this...good luck...peaCe
Old Mar 12, 2003 | 08:29 PM
EFLaosGirl's Avatar
Default Re: axles aren't going in! help (incubus)
Did i fail to mention that its turbo? Thats why i decided to run with the ls tranny.
Old Mar 12, 2003 | 08:33 PM
EFLaosGirl's Avatar
Yeah, the frame is all f*&%ed up. I just got a history report on carfax a few minutes ago and found out that the car has been in an accident 3 times. The last one was in 99. The car was declared "complete loss".
Old Mar 12, 2003 | 11:41 PM
Malgerus's Avatar
Always nice. Have you ever considered getting it "stretched" at a body shop? I hear they can attach it to big *** chains with hydraulic motors that pull the car into shape. I believe Sport Compact Car did this with their CRX project.
Old Mar 13, 2003 | 04:35 AM
EFLaosGirl's Avatar
yeah there is a place around here that does that, but i dont really know how much it would cost, and also would it be really worth it?? would i be better off getting another car???
Old Mar 13, 2003 | 08:06 AM
andrew dc's Avatar
still trying to understand how the frame is involved in this? axel on the passenger side plugs into the tranny directly... remove the suspension to clear more room, or just the fork.. plugs into the knuckle, replace suspension fork... bolt up, button up, and you are done!
Old Mar 13, 2003 | 08:16 AM
incubus's Avatar
y didn't u just get a b18A/B then?
is there damage to the wheel wells or engine bay around the motor mount points?
Old Mar 13, 2003 | 08:45 AM
EFLaosGirl's Avatar
initially, the motor was built for an eg. Sold that so we could begin another project. So the I decided to put the motor into my car. That is untill i get everything that i need for my setup. No damage to the wheels or the engine bay that I can see.
[Modified by EFLaosGirl, 5:46 PM 3/13/2003]
Old Mar 13, 2003 | 08:59 AM
serious's Avatar
i'd pull the engine out and find another car to put it in. if your frame is bent then just write off the car, it's almost impossible to pull it totally straight, and for what it's going to cost you you could probably find a shell in really nice shape.
Old Mar 13, 2003 | 10:26 AM
EFLaosGirl's Avatar
Default Re: axles aren't going in! help (serious)
Well everyone, *sighs*. I guess there is just one thing left to do. I just have to buy another car. (reaches in her pockets).....(lint) *shakes her head* THANK YOU all for your reply's
Old Mar 13, 2003 | 11:17 AM
serious's Avatar
if you're not in a rush, try and find one with a blow transmission and/or engine. you should be able to pick it up very cheap like that. you could also try and buy one from a junkyard (since you'll have parts to replace whatevers missing), and try going to a police auction. montgomery county, md, has an auction every third saturday of the month (behind the mva on clopper rd) and you could pick one up there for cheap. if you take your time you should be able to find something for pretty cheap.
Old Mar 13, 2003 | 01:07 PM
EFLaosGirl's Avatar
thanks for the info about the auction. i will try to go up there the next time they have one.
Old Mar 13, 2003 | 11:13 PM
jdmDXrex's Avatar
what axles were you using? also take pics im sure htat would clear up a lot of ?'s.............
BTW you should be using 90-93 Teg axles.......
