idleling problems help !
Old Mar 12, 2003 | 06:07 PM
SebAyatollah's Avatar
Default idleling problems help !
i was sooped to run my car and i couldnt wait any longer , so i slapped on a d- series distributor and a ecu from a singlebanger dx nonvtec . now once i start the car it idles at like 2 gees then like a min later it goes up and down like if i was tapping the gas from 2k to 1 1/2 constantly up and down but once the car is warmed up . it just chills on like 1k ...im not facing any power problems or anything ,thing pulls like a beast rus good ..the only issues imhaving is once the car is cold idles nutty like that ..could it be that im using a d series distributor and ecu. rght now i dont have the cash to buy a dist or ecu ,..
Old Mar 12, 2003 | 06:12 PM
Default Re: idleling problems help ! (SebAyatollah)
sorry about my spelling and typing is horrible !!
Old Mar 12, 2003 | 06:14 PM
TheIntegraGuy's Avatar
Depending on what motor/motor set up you have, it could be alot of reasons. Maybe you IACV is messed up...or maybe even a messed up VAC line. If anything, I would guess it's the IACV. Other things can be stupid little **** such as TPS, Coolant Temperature Sensor and a bunch of other bullshit...Check your timing and TPS and work from there..Good Luck
Old Mar 12, 2003 | 06:38 PM
SpoonFedHatch's Avatar
easiest/fastest/most effective solution to 90% of these problems ist he IAC screw....there is a screw on the throttle body with a slot in it...get a screwdriver, turn it while idling until your idle sounds half decent
Old Mar 12, 2003 | 06:42 PM
slomofo's Avatar
GDD Member
Default Re: idleling problems help ! (SpoonFedHatch)
Then the idle would be different when the car is warm. He said that he only has this problem when it is cold.
Old Mar 12, 2003 | 06:53 PM
poison's Avatar
take off the IACV and wash the little net with some carb cleaner.
that's most likely the problem.
Old Mar 12, 2003 | 07:59 PM
Default Re: idleling problems help ! (slomofo)
thanx for the help will do tomorrow .
DCRX89
Sep 18, 2014 01:35 PM
dloc82295
Nov 27, 2012 09:14 AM
dtran
Engine Management and Tuning
Nov 4, 2010 01:04 PM
riftonthemind057
Mar 27, 2008 01:08 PM
outlawcry7
Jun 22, 2007 11:25 AM
