Need help installing greddy oil pressure, and oil temp gauge!
Old Mar 12, 2003 | 04:52 PM
vtec69's Avatar
Default Need help installing greddy oil pressure, and oil temp gauge!
I am installing a greddy oil pressure gauge, and oil temp gauge using the adapter that goes in between the oil filter, and the block.
No matter what i do it still seems to leak?
Also i wired everything and the guage light up but they dont work?
BTW the gauges are electric
TIA
-Brian
Old Mar 12, 2003 | 06:00 PM
vtec69's Avatar
Default Re: Need help installing greddy oil pressure, and oil temp gauge! (vtec69)
fixed the leak but now the gauges will only light up and not work!?!?!
Any suggestion?????
Old Mar 12, 2003 | 06:03 PM
mr.beeks's Avatar
yeap full throttle sucks big time
cause you end up taking your car back as soon as they hand it to you...
have you tried
teflon tape before installing
this should keep from leaking.
Old Mar 12, 2003 | 06:08 PM
vtec69's Avatar
Default Re: Need help installing greddy oil pressure, and oil temp gauge! (FRANCISCO FLORES)
yeah full throttle sucks monkey *****
but i fixed the leaks but cant get the gauges to work
i need sugestions please
Old Mar 12, 2003 | 06:10 PM
mr.beeks's Avatar
kenny
"ill get back to you on that tomorrow"
LOL
Old Mar 12, 2003 | 06:12 PM
vtec69's Avatar
I loved it when he would say that my car would defenitly be done by today and not get it back til 5 days later
kenny
LOL
Old Mar 12, 2003 | 06:30 PM
mr.beeks's Avatar
just like him or his other boy
LOL
well back to the issue
what connections have you done
explain???
Old Mar 12, 2003 | 07:10 PM
vtec69's Avatar
The only wire i didnt connect is the ignition wire cause my friend said that i dont need that one connect
Old Mar 12, 2003 | 07:15 PM
mr.beeks's Avatar
there is your problem
how will the system know the car is on
right now is just getting raw power straight from the battery
I guess
Old Mar 12, 2003 | 07:24 PM
vtec69's Avatar
the reason why i didnt hook up the ignition wire is cause when i installed my tach i didnt hook up that wire and the tach works fine
Old Mar 12, 2003 | 07:26 PM
mr.beeks's Avatar
well different equipment right
just give it a little juice and see what happens.
it wouldnt hurt to try right
Sassafrass
17
Dec 14, 2006 02:10 PM
JM Performance
Aug 9, 2005 06:22 PM
Phaze2 Mike
Jan 9, 2004 06:27 PM
vtec69
Mar 12, 2003 10:31 PM
vtec69
Mar 12, 2003 05:54 PM
