DC5 R seats and Steering wheel pics
this is what the si stuff looks like in the DC5, it all went in with no problems at all, the wheel fits perfect, and the seats have 3 of the 4 bolts in them, the inner rear bolt has to be streched out toward the back to fit into the hole and I have not done that yet but they work just fine with 3 for now. They fit snugger than the stock leather seats. I have a couple sets of seats and wheels if you guys are interested in getting them. let me know. later
[img]http://www.we-todd-did-racing.com/wetoddimage.wtdr?i=wNjk0NDU2czQxM2RmZDMxeTU0MQ%3D% 3D[img]
[img]http://www.we-todd-did-racing.com/wetoddimage.wtdr?i=wNjk0NDY2czQxM2RmZDMxeTU0MQ%3D% 3D[img]
[img]http://www.we-todd-did-racing.com/wetoddimage.wtdr?i=wNjk0NDc2czQxM2RmZDMxeTU0MQ%3D% 3D[img]
[img]http://www.we-todd-did-racing.com/wetoddimage.wtdr?i=wNjk0NDg2czQxM2RmZDMxeTU0MQ%3D% 3D[img]
[img]http://www.we-todd-did-racing.com/wetoddimage.wtdr?i=wNjk0NDk2czQxM2RmZDMxeTU0MQ%3D% 3D[img]
You better get that straightened out. A custom rail might be the way to go. You don't want the seat coming off the floor in a head-on.
As some si owners have learned, when you unplug the harness on the seats, even if you are just removing them to run wires or whatever, the SRS light comes on... side airbags or not.
Its almost like the brain gets tricked into thinking something depolyed. AFAIK, only a trip to the dealership can get your srs reset, and the light goes back to off, until...
[Modified by hatch2k, 2:49 PM 3/13/2003]
I actually have some more seats and steering wheels for sale if any of you are interested in getting some. just let me know if you want the stuff. later
The install isn't bad at all. You just un-bolt and bolt back in! Its that easy! Just let me know if you guys are interested in buying a steering wheel or anything because I've got some stuff for sale! Later
You need to follow the instructions for SRS. It has been a standard so that when tampered with by a non-knowing person, to then have the MIL on. That way it can be reset by a technician... for safety. To reset you must use a PGM tester! Just use the "service connector" next time. Also all SRS systems use a capacitor for deployment, so don't think that just unplugging your battery will stop them from going off.
On the EP, I believe the SRS light will come on if the connector is off and you start the engine. At least in mine, that's the case. I disconnected the airbag connector in the steering wheel AND started the engine. The light came on. If I disconnect it and re-connect again, the light will not come on if I didn't start the engine. I can't be 100% sure it is the same for side airbag at the seats since I didnt get that option.
I also followed the instructions found here https://honda-tech.com/zerothread?id=423252 to reset the light. Simple paperclip trick did it.
[Modified by hamproof, 3:00 PM 3/14/2003]
just curious on the seats; email me the price if you could......
djsandoz420@yahoo.com
hey let me know if youre interested in doing a Genuine 4-lug swap to match the seats and steering wheel
btw nice job on the install
