B20 swap was fine, now what!?!?!
Old Mar 12, 2003 | 12:46 PM
4drb16's Avatar
Default B20 swap was fine, now what!?!?!
Ok.
88 hatch with b20 converted to OBD1, everything was fine, untill today when I started the car, and it revs up for about 10 sec, then shuts off.
93 integra full harness/ 95 integra engine harness/ OBD1 injectors and rail on Skunk manifold/95 LS ecu........No resistor box....( no plugs on the harness for it )
Changed so far:
Main relay- 3 times ( i have 3 of them )
Fuel filter
Fuel pump works
Took off fuel return line and it is dumping fuel. ( into a fuel safe container )
Tightened throttle cable to try and keep it idle- doesnt work, just revs higher untill it shuts off.
No codes on 95 LS ecu
Grounds are good, all fuses are good, everything else works......
Everything was running fine, and driveable untill today? WTF!
What else can I do? I exhausted myself for a while, and I cant figure it out.
Any help would be appreciated .
Old Mar 12, 2003 | 12:58 PM
YumVTEC's Avatar
Default Re: B20 swap was fine, now what!?!?! (4drb16)
try changing out the distributor. are you using an obd0/1/2 ecu? i know an obd1 ecu will not talk properly to an obd0 dizzy, and they could fry eachother out.
Old Mar 12, 2003 | 01:01 PM
slowpokesi's Avatar
check the dizzy, the rotor, check the map sensor if u have a spare.
Old Mar 12, 2003 | 01:03 PM
4drb16's Avatar
Default Re: B20 swap was fine, now what!?!?! (YumVTEC)
The dist, and the ECU are OBD 1.
Brand new coil/ igniter in the dist.
Could it just be a ECU problem? I bought it used.
( but there are no check engine lights )
Changed map's from OBD0/1/2 nothing seems to help......
[Modified by 4drb16, 10:03 PM 3/12/2003]
[Modified by 4drb16, 10:04 PM 3/12/2003]
Old Mar 12, 2003 | 01:26 PM
customx_'s Avatar
New User
check your grounds?
Old Mar 12, 2003 | 01:34 PM
YumVTEC's Avatar
yes, it could be the ECU. try a spare obd1 you can borrow from someone or if you have one laying around...
Old Mar 12, 2003 | 02:33 PM
ricodemus's Avatar
could it be the ignition switch?
Old Mar 12, 2003 | 03:13 PM
4drb16's Avatar
Default Re: B20 swap was fine, now what!?!?! (ricodemus)
Grounds are all good.
Brand new ignition cylinder from honda.
Trying to locate another ECU right now....
BryanChunkMcC
Jan 18, 2014 07:40 AM
dylaxiin
24
Jan 5, 2012 04:02 PM
ironman85
14
Oct 30, 2010 03:02 PM
