what tool to use to cut hole bigger for CAI install? need help now!
Old Mar 12, 2003 | 12:12 PM
accordfreak93's Avatar
Default FAWK!! what tool to use to cut hole bigger for CAI install? need help now!
aight, got everythin doen and off but come to find i dont have the rite tool to make the stock hole bigger. what exactly do i need to do this. i have a dremel, that didnt work. what do i use!
munscher's Avatar
Default Re: FAWK!! what tool to use to cut hole bigger for CAI install? need help now! (accordfreak93)
a dremel should work fine with the right bit.... i used a dremel to widen the hole on my 93 prelude
Old Mar 12, 2003 | 12:37 PM
93accordEX's Avatar
yea I also used a dremel. just put on a cutting wheel and you're good to go.
Old Mar 12, 2003 | 12:39 PM
95sihb's Avatar
Default Re: FAWK!! what tool to use to cut hole bigger for CAI install? need help now! (munscher)
if you got a (re-ci-pre-kate-ing ) saw also known as a electric jig saw take it to home depot and ask for the a blade that will cut metal and there you go . if you dont have a recipricating saw you can rent one from homedepot for a few bucks. that will do the trick.
Old Mar 12, 2003 | 12:45 PM
carolinaACCORD's Avatar
drill + hole-saw
Old Mar 12, 2003 | 02:26 PM
mrnicolas's Avatar
Default Re: FAWK!! what tool to use to cut hole bigger for CAI install? need help now! (carolinaACCORD)
I used a hammer, drill, hacksaw and a dremel.
Old Mar 12, 2003 | 03:15 PM
Default Re: FAWK!! what tool to use to cut hole bigger for CAI install? need help now! (mrnicolas)
aight thanks guys.
Old Mar 12, 2003 | 04:42 PM
iam7head's Avatar
lol, monkey wrench, hammer for a fast, nasty looking hole
jig saw, drills(no dremel, it's for ***** jk) will be your best friend.
make sure you get those metal cutting, drilling bit/blade
Old Mar 12, 2003 | 08:42 PM
ichibanjap's Avatar
Default Re: FAWK!! what tool to use to cut hole bigger for CAI install? need help now! (iam7head)
I used an electric grinder, does the job pretty fast.
Old Mar 13, 2003 | 10:11 AM
Default Re: FAWK!! what tool to use to cut hole bigger for CAI install? need help now! (ichibanjap)
i used a sawzaw last nite. worked pretty well. had to use a hammer a little to even it out. worked just fine tho. thanks for the help.
Old Mar 13, 2003 | 11:36 AM
95sihb's Avatar
damn you used a f-in big saw to cut the hole with , were the blades teeth far apart, if they where i bet it keeped jaming/grabing on the metal and thats why maybe u have to use a hammer to tap the edges of the metal flush. oh well make sure you use some anti-rust to prevent the edges from rusting.
Old Mar 14, 2003 | 12:39 AM
rustyeleio's Avatar
I didn't check the clearance behind the hole on my 92 accord but, if you use a reciprocating or jig saw, be sure you have enough clearance behind so you don't pole little dents with the blade tip.
Old Mar 14, 2003 | 07:49 AM
Default Re: FAWK!! what tool to use to cut hole bigger for CAI install? need help now! (rustyeleio)
haha yeah it was a big saw, worked fine tho. thanks for the input guys.
dv8omega
Honda Civic (2006 - 2015)
Oct 21, 2014 04:28 PM
Hatchless96
Honda Motorcycles
10
Sep 9, 2008 03:00 PM
DrGrEeNtHuMb
Welding / Fabrication
13
Jun 4, 2008 07:57 PM
Ca$h
Jan 13, 2005 02:22 PM
Flamenco-T
May 4, 2003 07:02 AM
