ZC Info Needed - OBD0 & OBD1 Differences
I ordered an OND0 ZC motor but received an OBD1 ZC ('92) motor. My questions are:
Are the distrubtors interchangeable? Can I use my OBD0 (1990 Civic DX) distributor on the OBD1 ('92 JDM) motor?
If I can interchange the distributors is there any other reason why I shouldn't use the OBD1 motor?
Any educated replies would be appreciated.
Thanks
Jon Black
Thanks
Jon Black
OBD0 and OBDI diz are different. mechanicly/electronicly and cann't be interchanged. You may be able to use you OBD0 DX diz if your ZC has the Cyl position sensor on the exhaust cam, if not would have to use a HF/SI diz or convert to OBD1 with OBD1 ECU
theidealone
Apr 14, 2008 06:21 PM
90civichbsi
Feb 17, 2005 06:47 PM
