Oy Vey! I fried my guage cluster!
Old Mar 12, 2003 | 11:47 AM
FourthGenHatch's Avatar
Default Oy Vey! I fried my guage cluster!
You think I could solder on a wire and try and fix it or should I just get a new one?
If I just soldered a wire from one part to the other it might work, I might as well try I guess.
The problem it causes is the temp gauge and the gas level needle are sort of going up and down. I replaced my thermostat and put in new coolant. I drove around and had the same problem. I can touch my radiator and its cold and the fans work great. My car can sit for about 5 minutes and the header is cool enough that I can touch it and it doesn't burn me. So I know the engine is running cold. It just annoys me thats all!
Old Mar 12, 2003 | 12:05 PM
Outsane's Avatar
Default Re: Oy Vey! I fried my guage cluster! (FourthGenHatch)
uhhmmmm..
HOW? did you do that..
Old Mar 12, 2003 | 12:10 PM
Default Re: Oy Vey! I fried my guage cluster! (Outsane)
Well I did a battery in the trunk thing a few days ago. All I can think of is that some of my stuff including the starter got fried. Perhaps from the a pos grounding or something.
Here is my fix, I'm going to go out and test it...
Old Mar 12, 2003 | 12:19 PM
Ef Whore's Avatar
that fix should do the job....if not I can get my hands on 88-89 Si clusters...if that's your year.
Old Mar 12, 2003 | 12:47 PM
zCivic's Avatar
Default Re: Oy Vey! I fried my guage cluster! (Ef *****)
B4 you plug it in your sure that those two place go in line with each other right??? Follow where the wires go and if that are in line with each other they should be fine...
Old Mar 12, 2003 | 01:17 PM
Slurp56's Avatar
Default Re: Oy Vey! I fried my guage cluster! (zCivic)
I have the same problem, I am honestly not sure what I did. But I just soldered a piece of wire to connect the path and everything works.
Old Mar 12, 2003 | 01:27 PM
itr-j's Avatar
Default Re: Oy Vey! I fried my guage cluster! (Slurp56)
why did that happen?
Old Mar 12, 2003 | 01:55 PM
I went out and tested it and it worked perfectly, cheap and easy fix!
Old Mar 12, 2003 | 03:04 PM
Hcivic88's Avatar
Default Re: Oy Vey! I fried my guage cluster! (B8TeenRex)
sweet. lol, you've been having a lot of problems this past week, good to hear some stuff is starting to work again though.
on the ghetto fix
Old Mar 12, 2003 | 04:02 PM
Heres a rundown of what broke on my car...
-Did battery in the trunk, worked fine for a day.
-Came outside next day car wouldn't start, wouldn't crank and wouldn't kick start.
-Replaced the starter and still nothing.
-Messed with the clutch sensor wires and then got it to crank.
-Wouldn't start but it had fuel and spark.
-Cranked it and finally it started ran fine for several hours.
-Temp needle and gas level needle would jump around.
-Replaced thermostat, didn't stop that needle.
-Remembered puff of smoke I saw come from around the gauges when I tried to start it, found fried wires.
-Made a jumper for it and it worked.
At the moment my wiper relay is sort of messed up, other than that everything seems fine.
Old Mar 12, 2003 | 04:36 PM
89civicdx's Avatar
this is why you guys should be runing a fuse as close to the positive terminal when you put the bat in the trunk
Old Mar 12, 2003 | 04:52 PM
Default Re: Oy Vey! I fried my guage cluster! (89civicdx)
I have one. None of my fuses were blown though.
Old Mar 13, 2003 | 07:19 AM
RapeV-8's Avatar
i got an extra gauge cluster if u need it??
Old Mar 13, 2003 | 12:05 PM
90CIVICSI's Avatar
Default Re: Oy Vey! I fried my guage cluster! (igotcrx)
I have one for sale on the Bay right now if your in need!! It's in KM's too!!]
<A HREF="http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=2407312507&ssPageName= ADME:B:LC:MT:1
" TARGET="_blank">http://cgi.ebay.com/ebaymotors/ws/eB...ADME:B:LC:MT:1
</a>
Old Mar 13, 2003 | 12:31 PM
AbaZ's Avatar
I have either SI cluster you need
88-89 or 90-91
45 shipped
Jeff
808zrk
Dec 5, 2014 08:47 PM
Fatty Wagovan
May 4, 2012 11:38 AM
T_98 COUPE EJ7
Apr 7, 2011 11:07 AM
iRIDElow
Mar 31, 2010 04:14 AM
folta2169
Dec 3, 2007 03:14 PM
