valve clearence for a 96 ls
Old Mar 12, 2003 | 11:13 AM
dip-set's Avatar
Default valve clearence for a 96 ls
can anyone tell me what the valve clearance should be set at...intake and exhaust for a 96 ls...and if i were to just drop some itr cams in a ls engine any benifits with just the cams if even possible...thanks
Old Mar 12, 2003 | 11:37 AM
Eva01's Avatar
Default Re: valve clearence for a 96 ls (teg-your-it)
B18B valve specs:
Intake: 0.003" - 0.005" (0.08mm - 0.12mm)
Exhaust: 0.006" - 0.008" (0.16mm - 0.20mm)
I don't believe VTEC cams are a straight drop in mod for a Non VTEC engine. The vavletrain is not equipped w/ LMA for the VTEC lobe when not engaged. HTH
Old Mar 12, 2003 | 11:40 AM
dip-set's Avatar
Default Re: valve clearence for a 96 ls (Eva01)
thaaaaank you...so long as its within those specs im good right...
Old Mar 12, 2003 | 11:41 AM
Eva01's Avatar
Your welcome and yes!
thumper64
Feb 23, 2009 02:55 PM
alexsracing
May 31, 2008 07:02 AM
blake_mp
Aug 13, 2007 02:28 PM
tegra96
Apr 9, 2006 07:47 PM
mRvYbEs
Jan 29, 2003 05:49 AM
