lift points on engine - where the #*!* are they?
Old Mar 12, 2003 | 06:08 AM
serious's Avatar
Default lift points on engine - where the #*!* are they?
the points where you attach the lift chains to an engine. are they normally attached already to the engine, or is it something that you have to buy and bolt on? neither the engine coming or nor the engine going in have the attachment points on them.
Old Mar 12, 2003 | 06:30 AM
RCautoworks's Avatar
Default Re: lift points on engine - where the #*!* are they? (serious)
You could wrap the chain around the engine a couple times, or you could use the side mount and there is one by the front of the trans, atleast on my b16 there is. I can't remeber about the d15. Anyways if you just use 2, make sure the engine don't flip forward or back. And I would hook it up at more then 2 points, because what if somthing happens to the one point and it snaps.
Old Mar 12, 2003 | 06:44 AM
USDM 4G VTEC's Avatar
normally u use a starter bolt tru the chain and aonther bolt on the hole next to the headers..... where the PS pump usually is..... works fine
Old Mar 12, 2003 | 06:45 AM
fastcrxsi90's Avatar
From: the asshole of america..., upstate new york, USA
when i took out my a6 you just bolt one end of the chain to the front side of the tranny and one to the rear side of head (10x1.25mm bolt). its a pain in the *** if you don't have one of those leveler things!
Old Mar 12, 2003 | 07:39 AM
spun Vtec's Avatar
Default Re: lift points on engine - where the #*!* are they? (90blackcrx)
wtf??????
rlmfao
Old Mar 12, 2003 | 09:44 AM
Default Re: lift points on engine - where the #*!* are they? (4gsicivichatch)
Why not, I did this when I took my d15 out. I also wraped one around the new engine, put it threw the intake mani running onto my header. My engine was not falling for sure. O I also had 2 other chains connecting at the main point to. The 1 around the engine was just for peace of mind. Plus the engine tends to lean back if you just hook it up on the sides.
[Modified by 90blackcrx, 12:45 PM 3/12/2003]
Old Mar 12, 2003 | 11:37 AM
Malgerus's Avatar
I use 1 small bolt for behind the cylinder head, and then 1 of the tranny bolts (if the engine is attached to the tranny).
Old Mar 12, 2003 | 03:27 PM
Hcivic88's Avatar
haha, I did something similar to this too, but instead of using a chain to go around the engine, i used a big strap, held up fine and it was just a little d15b2 so its not like it weighed much. I wrapped around the intake manifold and the exhaust manifold, seemed to work ok.
actullay i have a pic
Jsun25
Apr 18, 2017 05:29 PM
B_Swapped93
Sep 14, 2013 12:23 AM
Prof007
15
Feb 12, 2009 07:12 AM
aznguy0087
Jul 5, 2007 11:22 AM
Blaze45
Oct 18, 2002 07:45 PM
