Individual throttle bodies for K20 YUMMY...
Old Mar 11, 2003 | 07:02 PM
Pacman
Guest
Posts: n/a
Default Individual throttle bodies for K20 YUMMY...
Made a Prototype ITB. This is going to be on my K20 type r motor trying to do some R&D. If it makes good power then it is going to be up for sale.
Enjoy
Old Mar 11, 2003 | 07:15 PM
Goy091's Avatar
Default Re: Individual throttle bodies for K20 YUMMY... (Pacman)
whoa, crazy. howd you make it?
Old Mar 11, 2003 | 07:19 PM
Pacman
Guest
Posts: n/a
Default Re: Individual throttle bodies for K20 YUMMY... (Goy091)
It took about 2 months to make and the DR. made the Individual throttle bodies
Old Mar 11, 2003 | 07:59 PM
Del's Avatar
Del
so are you going to post this in every forum?
Old Mar 11, 2003 | 08:05 PM
Pacman
Guest
Posts: n/a
Default Re: Individual throttle bodies for K20 YUMMY... (Del)
Ya, Sorry EK body on ek form and motor on the DC forum...lol
[Modified by Pacman, 5:24 AM 3/12/2003]
Old Mar 11, 2003 | 08:18 PM
illi Adik's Avatar
Old Mar 11, 2003 | 09:36 PM
ArinX's Avatar
phatttt cant wait to drive it
Old Mar 11, 2003 | 09:46 PM
Pacman
Guest
Posts: n/a
Default Re: Individual throttle bodies for K20 YUMMY... (ArinX)
Ya right you are going to drive it...j/j
Old Mar 13, 2003 | 06:26 PM
808k20a2's Avatar
how much do you guesstamate the price for the throttle bodies?
Old Mar 13, 2003 | 06:40 PM
ArinX's Avatar
Default Re: Individual throttle bodies for K20 YUMMY... (808k20a2)
haha
like 6 grand but for you hell say like 9 haha
Old Mar 13, 2003 | 09:52 PM
Evoluti0n's Avatar
pretty tight...good job...whats the price on the ITB?
Old Mar 13, 2003 | 10:14 PM
ep3minivan's Avatar
Default Re: Individual throttle bodies for K20 YUMMY... (Evoluti0n)
verrrrrrrrrrrrry niceeeeeee
now how much?
Old Mar 14, 2003 | 04:23 AM
1 Special CTR's Avatar
Default Re: Individual throttle bodies for K20 YUMMY... (ep3minivan)
i could use rthat on my CTR
Old Mar 14, 2003 | 07:39 AM
merlyn's Avatar
Default Re: Individual throttle bodies for K20 YUMMY... (1 Special CTR)
that looks like the mugen (i thnk) itb for the b18........ what size are those? from my estimates, even 50mm tb's wouldn't be enough for our engine.
Old Mar 14, 2003 | 07:49 AM
Aquafina's Avatar
Default Re: Individual throttle bodies for K20 YUMMY... (merlyn)
From the mods you have listed, you don't need anything bigger than 50mm.
Ok, say you have a 65mm throttle body stock. Thats a little over 15mm for each cylinder. Now you have individual throttle bodies and thats 50mm for each cylinder, do the math.
Old Mar 14, 2003 | 08:46 AM
Brian*'s Avatar
Default Re: Individual throttle bodies for K20 YUMMY... (SuperStreetRX7)
Single throttle bodies with an intake manifold don't work the way you are describing. The incoming air is not partitioned into equal portions from the throttle body, it is essentially stored in the intake manifold and the air is "taken when needed".
Brian
Old Mar 14, 2003 | 01:09 PM
MJ23FE's Avatar
Default Re: Individual throttle bodies for K20 YUMMY... (Brian*Blue95M3)
That looks soooo hot!!! Let us know how it dyno's!!!
Old Mar 14, 2003 | 05:25 PM
merlyn's Avatar
Default Re: Individual throttle bodies for K20 YUMMY... (MJ23FE)
Even a 50mm setup offered by TWM is too small IMO. It will work fine for a basic street engine, but for really serious hp, it just won't do.
You need to examine the displacement per cylinder to see just how big the TB's should be. With a K20, we're looking at 500 cc per cylinder. This is on par with the big liter twins like the SP2 and Ducati 998. The SP2, in preparation for homologation and racing setup, uses _62_ mm throttle bodies!!
I know of several race teams in import drag racing that won't use the available ITBs on their all-motor cars because they'd lose power vs. their optimized intake manifold setup. Not because an intake manifold is better, but because the ITBs just won't flow enough.
How many cylinders are breathing from the intake plenum at one time on an I4 engine? In reality, its one. But because of the close proximity of intake pulses at high rpm, you might consider it to be the equivalent of 2 cylinders at one time if the plenum is small.
On a top all-motor Honda engine, you're looking at TB's of 70-75mm in diameter. Combine that with a large intake plenum (say 2.0 liters) and each cylinder is basically breathing through a big throttle body by itself.
The problem with such huge throttle bodies and plenums is that you're killing throttle response and low rpm/light throttle flow velocity. Going with smaller individuals gives you back all that part throttle and low rpm power/response while giving you all the top end you want (assuming proper sizing). Additionally, the shaping of the flow path on ITBs tends to be far more ideal than your typical intake manifold (although the RSX-S manifold is really, really good for an OEM).
Old Mar 14, 2003 | 06:50 PM
Pacman
Guest
Posts: n/a
now how much?
Don't know yet...
Old Mar 14, 2003 | 08:27 PM
Viorent GRIP!'s Avatar
Freakin Marouj!. You're nuts man!
BTW wassup it's Mike Dan's homie
Old Mar 15, 2003 | 04:43 PM
Pacman
Guest
Posts: n/a
Default Re: Individual throttle bodies for K20 YUMMY... (Viorent GRIP!)
Waazz up man How is your car?
Old Mar 18, 2003 | 11:22 AM
FrostyDC4's Avatar
"Haters Gonna Hate"
25 Year Member
Default Re: Individual throttle bodies for K20 YUMMY... (Kris79)
yummy
Old Mar 18, 2003 | 06:31 PM
BlackKnight's Avatar
Default Re: Individual throttle bodies for K20 YUMMY... (FrostyDC4)
man when is that gonna be on your car?
lets hear some more details once it's on.
and how much
MatthewMenze
Dec 4, 2012 02:02 PM
gsp ej1-em1
Northern California (Sales)
10
Jan 7, 2007 11:09 PM
Pacman
125
Sep 28, 2004 11:29 AM
B-Series Sol
Aug 21, 2002 09:55 AM
StockBlkEK
Aug 5, 2002 04:09 PM
