hot tanking GSR head
Old Mar 11, 2003 | 06:00 PM
hatchy's Avatar
Default hot tanking GSR head
Can you steam tanking a complete GSR head, or do you have to tear it down first? I just want to clean it up, and clean up the thick carbon build up... how much does it usually cost?
Old Mar 11, 2003 | 06:03 PM
Broken Gearbox's Avatar
Default Re: hot tanking GSR head (hatchy)
id like to know too...
Old Mar 11, 2003 | 07:21 PM
earl's Avatar
Default Re: hot tanking GSR head (x lP lL i c i t)
You can do that. Just make sure the chemical used will not hurt the valve seals.
Old Mar 11, 2003 | 07:36 PM
hatchy's Avatar
Default Re: hot tanking GSR head (earl)
Is there another way to clean out the carbon build up? Thanks
Old Mar 11, 2003 | 07:41 PM
Tbone's Avatar
Be carefull that its not triclorethene. i did my head and then realized that triclor embrittles titanium(retainers). Nice litle paperweights now. And you cant see it visually either.
Old Mar 11, 2003 | 07:43 PM
Default Re: hot tanking GSR head (Tbone)
how much did it cost to get it hot tanked?
Old Mar 11, 2003 | 08:36 PM
Tbone's Avatar
I work there so anyhing I need cleaned, blasted, glass peened, Ivd aluminum plated and conversion coated, I do myself I wish we had anodizing tanks here like our parent company does. I need to find out some info on moly coating because I could probably spray it here at work.
krazych0p
Oct 26, 2008 08:26 PM
thehondaguru
Mar 14, 2004 07:59 PM
275Performance
Dec 21, 2002 08:11 PM
