Well rounded or all out drag?
Old Mar 11, 2003 | 05:13 PM
MooreBoost's Avatar
Default Well rounded or all out drag?
As you all know there are many options in building up your teg, all drag?, all handling?, a nice median? Well, as of now, Im all drag, for the most part. Setups at the bottom....My question, if you were in my boat, would you finish off the engine, or finish off the handling?
Plans for engine-
Hondata
Injectors
Water Injection?
Tuning
Plans for handling-
Good tires
Front/Rear Sway bars+Tie bar
Sparco Torino (Driver only)
5pt Harness
Autopower 4pt rollbar
I know the seat setup is alot of show, but I like it personally. I dont have the money to build the bottom, nor the down time for my car.
I think Id rather have a nicely rounded car that an all out drag car. What do you think?
gmoore
2000 GSR, JRSC@10psi, Boost upgraded, BTC, MAP mod, I/H/E, Clutch/LSD/Flywheel, MSD ignition, Skunk2 cam gears, H&R Race/Koni 5-ways.
Old Mar 11, 2003 | 05:18 PM
garados's Avatar
Default Re: Well rounded or all out drag? (gmoore379)
I would take care of the handling department first, but do whatever you think you would enjoy more.
Old Mar 11, 2003 | 05:46 PM
MooreBoost's Avatar
Im a speed freak, but I dont think I want to spend all that on minimal gains, as I cant wreap the benefits of a built bottom. Im leaning to handling.
gmoore
Old Mar 11, 2003 | 07:31 PM
SSBP DC2's Avatar
imo, integras are decent little cars, upgrade a little here, a little there and you'll enjoy driving it much more since driving consist of more than just going straight.
Old Mar 11, 2003 | 08:16 PM
sa21199's Avatar
Default Re: Well rounded or all out drag? (SSBP DC2)
get a roll bar
Old Mar 11, 2003 | 08:33 PM
HKJ's Avatar
HKJ
Default Re: Well rounded or all out drag? (sa21199)
seeing that your car is already boosted at 10psi, maybe it's time to find a way to get some power to the ground?
Old Mar 12, 2003 | 04:38 PM
MooreBoost's Avatar
Default Re: Well rounded or all out drag? (HKJ)
Its got an LSD, better tires are coming either way, and traction bars are outta the question if I go for handling too.
And your right, driving is more than just straigh ahead, so Im still leaning to handling.
gmoore
Old Mar 12, 2003 | 04:41 PM
f22btwincam's Avatar
how about some pads and rotors? just a thought, you should be able to stop just as well as you accelerate too
[Modified by f22btwincam, 5:41 PM 3/12/2003]
Old Mar 12, 2003 | 04:42 PM
illi Adik's Avatar
Id say tune it and then go for handling.
Old Mar 12, 2003 | 04:44 PM
MooreBoost's Avatar
Default Re: Well rounded or all out drag? (Jackson4Door)
It has the AEM big brake kit, minus the rotors (on stock swirlies ) And its tuned.
gmoore
bergenholtzracing
Nov 24, 2008 09:36 AM
brian g
Jun 3, 2004 01:19 PM
blackitrspec
Oct 22, 2001 11:44 AM
itr1236
Jul 6, 2001 06:50 AM
