D16Z6, a couple questions... dizzy and mounts?
ok if the car was converted to obd1 (I am not doing the swap) which dizzy would I use, a 92-95? My car is a dx, and will be converted to the mpfi with the swap (using the z6 IM)
also, I would use 88-91 mounts correct? I need this cleared up because I kept reading about 94-95 mounts are different, blah blah...
I tried a search, but too many results to find a simple dizzy question
If you are using the OBD1 ECU (P28) then you will need to use the OBD1 dizzy as well as a 4 wire O2 sensor.
You will use all the 88~91 mounts. You won't use the 92~95 tranny.
Yes you need OBD1 Diz 92-95 Z6 will be perfect....Motor mounts use the 88-91 off your old block. Need to mod the Driverside mount to prevent if from hitting the timing belt
good thing you remembered the O2 b/c that one slipped my mind
[Modified by zCivic, 8:58 PM 3/11/2003]
alright, if the car is converted to obd-1, you would use the 92-95 dizzy on it.
as for the mounts, yes, you use the 88-91 mounts. the one drivers side mount is the only one you'll have to change, you just switch that mount with the one off your 8-91 engine, bolt it up to the tranny, and drop it in
hope this helped
hope this helped
ok, so 92-95 dizzy, and would the 4 wire o2 sensor come with the swap? the dizzy should right?
plan on ordering from NIppon motors
ok that's not bad, thanks a lot
what is all this repinning the dizzy then? is that for people not converting to obd1?
[Modified by SteveeeO, 9:01 PM 3/11/2003]
yes you may need to repin the Diz depends on where the instructions are coming from. Some Hasport goes by the sensors which are different colored from 88-91 and 92-95 while storminmatt's match colors from the Diz to the ECU. Also gonna need to use either the round SI/HF type plug from the Engine harness and Diz plug or switch it to the gray ones from 92-95
ovsep86
May 3, 2006 11:18 PM
