4th gen tranny swap
Old Mar 11, 2003 | 03:49 PM
khmertek's Avatar
Default 4th gen tranny swap
hey i just coverted my 93 accord lx 10th ann from an automatic to a 5 speed. 2 day job. i used a trany of the same year and the lx model not the lx 10th ann. the swap went great but a couple of things i need help with.
1- the mount on the tranny (engine right side mont) is off about 1 inches to the back of the car. i had to pry it into place and if i tighten the mount nuts to the trany it will raise the tranny too high. IS THERE ANY SPECIAL MOUNTS OUT THERE TO MAKE IT WORK, OR WAT CAN I DO?
2- now that every runs, my abs light in the dash comes on after i start and drive the car for about two car lengths, CAN ANYONE HELP? remember i did swap the axles from auto to 5 speed axels
Any one with question or can help me please reply or contact me at khmaiprince1@aol.com for quick response
THANX
Old Mar 11, 2003 | 04:55 PM
urbanlegend21's Avatar
New User
Default Re: 4th gen tranny swap (khmertek)
did you get axles with the ABS sensor ring on them?
Old Mar 12, 2003 | 07:05 PM
khmertek's Avatar
Default Re: 4th gen tranny swap (urbanlegend21)
the axels came with the tranny
wat i did was replace my automatic axles with the manual axles
cuz the 5 speed tranny will not work with the automatic axles
the axles and tranny came out of an 93 accord lx
so it should be a simple axles swap
Old Mar 12, 2003 | 07:06 PM
khmertek's Avatar
oh yea, i don't know anything about the abs sensor rings.
can u help me out
Old Mar 13, 2003 | 04:29 AM
Stew Pidasso's Avatar
I don't know if the LX had ABS or not. You need to look at the axles (5spd ones) and right by the outer boot there should be a metal ring that looks like a gear with flattened worn down teeth. This is your ABS wheel sensor ring. Look at your old axles and you will see it. See if your new axles have that same ring.
Old Mar 13, 2003 | 04:38 AM
sauceman's Avatar
Default Re: 4th gen tranny swap (Stew Pidasso)
LX did not have ABS. You don't have axles that will enable your ABS to have a sense of the speed the axles are rotating. You got to replace it with either EX or SE axles or say byebye to ABS.
Old Mar 13, 2003 | 06:14 PM
khmertek's Avatar
Default Re: 4th gen tranny swap (sauceman)
hey thanx to the both of yah for the info, i'll check it out
Old Mar 13, 2003 | 10:26 PM
.bagged's Avatar
show us some pics when you finally complete it . and let us know how well it works
Old Mar 14, 2003 | 11:07 AM
khmertek's Avatar
Default Re: 4th gen tranny swap (bagged93accord)
hey, u guys r right. i see the abs ring on my old axles, and on my 5 speed axles, there r none . for now i can't do anything about it till i buy new axles, got to save some money. thanx to everyone for the help.
Old Mar 14, 2003 | 12:06 PM
You could always pull the CV joint apart and put the old ends on the new shafts. Replace the boot and repack the grease. It would probably be easier just to swap axles though.
Old Mar 14, 2003 | 12:12 PM
khmertek's Avatar
hey thats a good idea. thanx
i'm learning more and more
jmurphy
Nov 3, 2011 04:29 PM
zodiac
Nov 2, 2009 02:54 PM
Cannon Man
Jul 4, 2008 11:18 AM
