Where is My ABS wheel speed sensor?
Old Mar 11, 2003 | 02:32 PM
JLange's Avatar
Default Where is My ABS wheel speed sensor?
Alright after lowering my car, my ABS light is on, and some of my friends said that its probably my wheel speed sensors in the wheel wheel, where could i find these, pics would help too, thanks everyone
Old Mar 11, 2003 | 07:58 PM
AW's Avatar
AW
Default Re: Where is My ABS wheel speed sensor? (jtintegra)
ABS sensors are on your drive shafts not sure where the back ones are.
AW
Old Mar 11, 2003 | 08:34 PM
HKJ's Avatar
HKJ
Default Re: Where is My ABS wheel speed sensor? (AW)
they have too many gizmos on cars nowadays
Old Mar 12, 2003 | 04:21 AM
JimBlake's Avatar
They're not on the driveshafts. The sensors are mounted on the steering knuckle. Follow the only wire that goes to the knuckle. There's a toothed ring around the CV joint or the hub, the sensor sits real close to that as it turns. On the back, the toothed ring is on the hub, take off the brake rotor to see it.
Old Mar 12, 2003 | 06:03 AM
AW's Avatar
AW
Default Re: Where is My ABS wheel speed sensor? (JimBlake)
You are correct. I meant to say that the ring where the sensor reads is on the axel. I know this because when I put in a non-abs axel my ABS light went on.
AW
mijikai
Sep 8, 2012 04:23 PM
woszczy
Jun 3, 2012 08:05 PM
ColdScript
Jul 18, 2009 09:55 AM
dreams190
Apr 24, 2006 07:16 PM
Frozen E
Jul 27, 2003 01:53 PM
