Doing brakes this weekend, got some questions...
Old Mar 11, 2003 | 12:50 PM
dynamo's Avatar
Default Doing brakes this weekend, got some questions...
I am doing brakes on my girlfriend's 94 Accord Ex with ABS. I was going to replace the pads and resurface the rotors, but since the car has a lot of miles on it I am not sure if they are too thin, or if they have been replaced before. Does anyone know the acceptable thickness of the disc so that I can measure it out and just get new rotors if the ones she has are too thin?
Also, which brake pads would you guys recommend for daily driving? The car is never raced in any way, and is a simple daily driver. Anything other than OEM?
Old Mar 11, 2003 | 01:51 PM
Gennady's Avatar
New User
Default Re: Doing brakes this weekend, got some questions... (dynamo)
The minimum thickness is around 20mm.
Honda OEM works just fine.
If it hasnt been done in a while, flush the fluid as well.
Old Mar 11, 2003 | 02:09 PM
briq4's Avatar
Default Re: Doing brakes this weekend, got some questions... (Wont be beat)
Just remember with the rear calipers, they don't get compressed back in by using a clamp, you have to screw them back in... do NOT use a clamp on the back calipers.
Also why are you resurfacing them? are they warped? If not don't resurface them.
[Modified by briq4, 6:10 PM 3/11/2003]
Old Mar 11, 2003 | 02:51 PM
TypeSH's Avatar
Default Re: Doing brakes this weekend, got some questions... (briq4)
21mm for a 23mm rotor, 23mm for hte 25mm rotor.
Old Mar 11, 2003 | 03:52 PM
dynamo's Avatar
Is the bleeding process any different because the car has ABS?
Old Mar 11, 2003 | 05:15 PM
5LuGinTeg's Avatar
no bleed it the same way you would any other car. dont forget to watch ur brake fluid just to make shure you dont run out and suck in any air
also remeber to pump ur brakes after the brake job
Old Mar 12, 2003 | 03:37 AM
JimBlake's Avatar
Depends on the car...
My '95 Integra ABS unit has its own fluid reservoir & bleed valve. You bleed the main brakes like normal, then you bleed the ABS. My '98 Accord has no separate ABS bleeding, but the ABS plumbing makes it better to bleed both fronts first. So check a repair book for your car.
Old Mar 12, 2003 | 03:51 AM
urbanlegend21's Avatar
New User
Default Re: Doing brakes this weekend, got some questions... (JimBlake)
RR
LR
RF
LF
resurfacing rotors helps pad transfer
Old Mar 12, 2003 | 06:33 AM
Gennady's Avatar
New User
Default Re: Doing brakes this weekend, got some questions... (ScrewD07)
I would imagine sucking in air would be the least of his problem.
Old Mar 14, 2003 | 10:39 AM
dynamo's Avatar
What do you mean by that? Is there something I should be on the lookout for that I don't know about?
Old Mar 17, 2003 | 09:33 AM
dynamo's Avatar
So I tried doing them this weekend - the pads looked ok, so there was no need to replace them *yet*.
I did run into one major problem though - I couldn't take off the front rotors! It seemed that I needed to take off the axle bolt to release the rotor, and my air tools were unable to brake it loose. I didn't get a chance to pick up a breaker bar, so I guess it will have to wait until next weekend. Can anyone confirm that I need to take it off to get to the rotors?
Tenzo
Suspension & Brakes
May 24, 2012 01:04 AM
Civic_07
May 2, 2008 11:59 AM
Hatchd
Apr 3, 2006 10:40 AM
ursino2
Jul 28, 2004 09:45 AM
AU K20A2
15
Jun 4, 2004 08:24 PM
