Service Required Light
When I turn on my 98 Itr the Service light blinks 11 times anyone know what this means. My mods are cold air intake and exhaust.
That is really a good diagram of where it is, But you need to turn you ignition to the "on" Position, then feel along the bottom of the knee plate(about 4 inches to the left of the steering column, and press the 1way button for 10 seconds. As soon as you press it the light will stay on, then it will go off. Walla, no more light Maintenance done!!!
any itrs with higher milage - do you still have maintanance light flash? i don't think mine does that anymore. i'm past 60K now..
it means oil change.. look reset it put the key in and turn it to the on position then wait for it to stop flashing then hold the button that is under the dash to the right until the ligh goe out.. then start you car .. you wont see it for a few thousand miles .... then change your oil but dont confuse this for your check enging light. my check enging light came on and i blew up my transmition....other than that can i come swing at the playground drawing lol
a little ot: Where would that button be for an Acura MDX?
For the RSX, hold the reset button on the instrument cluster, turn the key on, and hold the button until the maintenance light goes out.
For the MDX, you hold both buttons on the right of the instrument cluster, turn the key on, and hold both buttons until the light goes out.
