P28 ECU Codes/ 96 LS Helms Are the Codes the Same?
Old Mar 11, 2003 | 10:03 AM
dabrown's Avatar
Default P28 ECU Codes/ 96 LS Helms Are the Codes the Same?
I check the search for ECU Codes and archived and did not locate this. When I check the codes for the ECU will the codes be the same as the one's listed in the Helms for the 96 Integra?
Old Mar 11, 2003 | 10:48 AM
Kataku2K3's Avatar
Default Re: P28 ECU Codes/ 96 LS Helms Are the Codes the Same? (dabrown)
Yes you will be fine... OBD2 gained more codes due to the parameters but you'll find all the OBD1 codes to be the same... Peace
Old Mar 11, 2003 | 11:07 AM
dabrown's Avatar
Default Re: P28 ECU Codes/ 96 LS Helms Are the Codes the Same? (Kataku2K3)
Thanks a Mil Kat.
710dabber
Jun 21, 2015 11:26 AM
reddcoupe
May 20, 2012 07:46 PM
Mr_Si-R
Apr 11, 2005 06:19 AM
g5r
Sep 3, 2003 06:28 PM
udctown
Dec 6, 2001 08:00 AM
