NE1 using CRX SI rear swaybars on DX?
Aftermarket CRX sway bars are not a good idea on the street unless you run both the front and back aftermarket bars. Running a stock front bar and 22mm rear bar will make the car very oversteer biased. This is preferred by autocrossers, but a dangerous situation on the streets.
I would get the SI stock rear sway bar and try that. People usually sell them for about $20. You will also need SI rear lower control arms because the DX ones don't have the mounting hole for the endlinks.
any sway bars back there will improve your handleing, as far as oversteer goes, dont get it if you dont want oversteer, if you can handle the oversteer then go for it, if not then dont do it, i have a stock SI on my DX with TEIN's on it and thats all it needs, i get plenty of oversteer on demand.... so its up to you, for me the $17 i spent was plenty
You will also need custom brackets to mount the sway bar to the underside of the car. The holes are there but they do not have the nuts welded to them. I had a set of brackets made.
the only reason you are saying this is because you cant drive, and are stupid beyond belief....
I have the 88dx hatch w/a crx rear sway bar. we had to weld in the mounts, but do be careful on the street with that oversteer b/c it's pretty quick b/c of our short cars. I've stepped out twice in downhill intersections on accident, and the rain is just making me be extra careful...but it ain't nothing you can't tell when it is about to happen or anything.
Well, I have 89 CRX Si suspension on my 88 DX... so the sway bars will bolt on? I have the bar from the 89 CRX and the mounting brackets for a 90 Civic Si...
black0hatch
14
Aug 11, 2008 08:51 AM
tysf
Aug 19, 2003 08:41 PM
The_PissingDog_Crx
Jun 27, 2003 11:56 AM
