Dohc Zc swap!!! pics inside too!
Old Mar 10, 2003 | 11:15 PM
thaiphob's Avatar
Nikon!!!
Default Dohc Zc swap!!! pics inside too!
Yesterday Sleeper[xsi], krzyangel710, GirlyGs-R and i went to Ayanami's house to do my dohc zc swap. when we got there we thought it was going to be an easy swap, and should be done within the day. WE WERE WRONG . taking the hyrdolocked Si motor was not that hard and took about an hour (with a couple smoke breaks and lunch). then we started prepping the dohc zc motor. took my old engine harness, dist., TB (b/c the tps sensor on the dohc zc was broken) and other misc parts ready for the swap.we bolted the exedy clutch to my stock Si flywheel and attached it to the tranny.
Getting the motor in without a cherrypicker was a lil tough but not that bad. we just slide the motor in from under and jacked it up from there. the most difficult part of the swap was getting the tranny bolted up to the motor. we tried for almost two hours trying to figure out what the deal was. first, we thought the clutch i bought was the wrong one. that wasnt the problem. then we pulled the tranny and noticed the dowel pins were all bent??WTF!!! the dowel pins on the motor and tranny were on and that why they wouldn't bolt up. then we tried again. Still it would go in!!!! were were about to call it a nite. we all went to take a brake so i kicked the jack where the tranny was resting and wham! the tranny just locked into place. after that everything went by so fast. within in hour my car was put back together and i had a new motor.
hydrolocked sohc zc
whats all that white stuff in the TB???
my new motor
the sohc zc out of my engine bay
another pic of the dropped sohc zc
GirlyGs-R and krzyangel710 got bored and took a nature hike
bye-bye sohc zc
ready for the dohc zc
Me(left) and sleeper[xsi] sliding the Dohc zc in
heres me getting ready to jack the motor up
bolting the drivers side mount was a bitch
Ayanami and me watching Sleeper[xsi] jump on the intake mani to bolt the rear mount
just gotta tweak out some bugs and its ready to terrorize the streets of Phoenix again!
[Modified by thaiphob, 1:28 AM 3/11/2003]
Old Mar 11, 2003 | 11:23 AM
ScottEK's Avatar
Default Re: Dohc Zc swap!!! pics inside too! (thaiphob)
Always impressed to see people put it in through the bottom, I've done a couple ZC swaps, check my sig for pics.
Old Mar 11, 2003 | 09:14 PM
thaiphob's Avatar
Nikon!!!
Default Re: Dohc Zc swap!!! pics inside too! (beta13)
it was pretty fun dropping it though the bottom.
Old Mar 11, 2003 | 10:06 PM
turbohf's Avatar
going from the bottom sucks ***, was a bitch when we did it. would have been a lot easier if we took the front crossmember out/off, no one has mentioned that
Old Mar 12, 2003 | 06:07 AM
Rob!'s Avatar
Default Re: Dohc Zc swap!!! pics inside too! (turbohf)
i did my 2 swaps through the bottom hell of a lot easier that way...check sig. for some pics
Old Mar 12, 2003 | 06:49 AM
USDM 4G VTEC's Avatar
Default Re: Dohc Zc swap!!! pics inside too! (RaceFacer)
i did my 2 swaps using cherry picker of a lot easier that way...check sig. for some pics
8894honda
Oct 19, 2006 11:44 AM
89SilverCRX
Aug 18, 2006 05:51 AM
contender
Jul 2, 2005 08:14 AM
IAIA
Dec 31, 2001 07:19 PM
