funny oil behavior
Old Mar 10, 2003 | 08:52 PM
d8168055's Avatar
Default funny oil behavior
does anyone have this "problem" -- when my engine is cold... or has been sitting for a while, the oil is down on the bottom hole of the dipstick... but after driving, it goes to its regular postion, slightly above the top hole...
anyone else do this?
Old Mar 10, 2003 | 08:54 PM
B2FiNiTY's Avatar
Default Re: funny oil behavior (d8168055)
Stupid Q: Do you wipe the dipstick then check?
Old Mar 10, 2003 | 08:55 PM
d8168055's Avatar
Default Re: funny oil behavior (B2FiNiTY)
no... what do u mean... i just pulled it out and looked at it
Old Mar 10, 2003 | 09:23 PM
Dirt's Avatar
Let's solve this problem right here. Add oil to the top mark when engine is cold. Done. Happy ricing.
Dave-ROR's Avatar
Default Re: funny oil behavior (BrewCityR)
lmfao. lol best reply lately. (not quite ever, sorry )
edit: PS: To be most accurate, fill the oil through the dipstick tube!
[Modified by FyrStarter, 1:24 AM 3/11/2003]
Old Mar 10, 2003 | 09:26 PM
vtec.dc2's Avatar
to check oil, take out the stick, cool the car for several hours, wipe it with cloth/paper towel,
place it back and pull it, anything lower than second dot/hole is low oil - add oil until it reaches second dot/hole
Old Mar 10, 2003 | 10:06 PM
d8168055's Avatar
actually, i did this already... and it raised it over the half a quart over the top hole...
Old Mar 10, 2003 | 10:10 PM
B2FiNiTY's Avatar
That's your problem. You have to pull it out and wipe it then insert again and check for an accurate reading. If you don't, the car splashes all over the place and the reading will be wrong.
Old Mar 11, 2003 | 06:50 AM
d8168055's Avatar
yes i konw... why ya'll acting like i've never done this before? or like im a ricer who never checks his oil? i would appreciate some valid input for a vaild problem... please re-read my first post
Old Mar 11, 2003 | 08:03 AM
Eva01's Avatar
The bottom mark on the dipstick is the where the oil level should be a when engine is cold. Top mark indicates oil level when engine is hot. When temps increase, metals and oils expand resulting in the higher oil level after engine has been driven. In other words, what you are seeing is normal. When doing an oil change just fill the engine up w/ 4qts of oil and your're set (assuming you check and top off oil regularly).
Edit: Your vs Your're
[Modified by Eva01, 6:36 PM 3/11/2003]
Old Mar 11, 2003 | 09:17 AM
Austin's Avatar
Default Re: funny oil behavior (Eva01)
THe bottom mark on the dipstick is the where the oil level should be a when engine is cold. Top mark indicates oil level when engine is hot. When temps increase, metals and oils expand resulting in the higher oil level after engine has been driven. In other words, what you are seeing is normal. When doing an oil change just fill the engine up w/ 4qts of oil and your set (assuming you check and top off oil regularly).
I believe that the stock Type-R specifications read 4.25 quarts...but I could be wrong.
Old Mar 11, 2003 | 11:05 AM
Haunt's Avatar
Default Re: funny oil behavior (Austin)
stephie1love
Aug 25, 2014 04:01 AM
exexexex
Nov 13, 2004 10:22 AM
B18Redline
Jun 10, 2002 02:40 PM
PY2KITR1060
May 4, 2002 01:30 PM
