toda header/ carsound cat ?'s on install.
Old Mar 10, 2003 | 07:29 PM
YellowR2000x2's Avatar
Default toda header/ carsound cat ?'s on install.
So were almost done with the install, but i was wondering what we should torque the spring bolts for the cat/header connection to? also what about the bolts for the header to block. hand tight god enough or should they be at a certain number? thanks!
Old Mar 10, 2003 | 08:18 PM
Padawan's Avatar
Darth ModerVader
Default Re: toda header/ carsound cat ?'s on install. (YellowR2000x2)
Header-to-head (it isn't actually the block) nuts/bolts should be 23 ft. lb. As for the header-to-cat. bolts, just tighten them reasonably, making sure the springs don't bind.
Old Mar 10, 2003 | 09:41 PM
Default Re: toda header/ carsound cat ?'s on install. (Padawan)
doh, your right, my bad.long day.. but thanks for the specs!
ShuaiGuy
Jul 31, 2004 08:34 AM
TeGGY_LS
Jun 8, 2004 11:24 AM
Rwecked
Aug 28, 2002 06:44 PM
hYpE-R-29
Nov 2, 2001 07:14 PM
NSX Bob
Oct 17, 2001 03:55 PM
