window fell of track
well...my stupid window finally went on me
. anyways when i used to roll up my window i had to straighten the window when i started to roll it up, but the other day i rolled the window down all the way n then later on when i went to roll it up it had completely fell off the track i had to pull the panel off and i got the window back into track. could it be the reglaltor?? how do you take off that inner metal panel that holds the regualtor. i cant figure it out! i appriciate the help i can get, i want to try to fix it myself before i spend money for it to be done professional
[Modified by SIMATIC, 3:24 AM 3/11/2003]
[Modified by SIMATIC, 3:25 AM 3/11/2003]
Just take off your door panel and you should be able to see what happen to it. Mine did that ones and it was just a loose skrew. Tightend it back up and havent had a problem yet.
its not any screws i checked that i wana see the regualtor up close because some told it me might just be a ball bearing that fell out in the crank, but i dont know how to remove that metal panel that holds the regualtor
you will need window glue, to glue the glass back onto the palstic tracks. i had to do this on my crx. i never was back to normal. the glue wouldnt hold. good luck.
i-want-a-crx
Oct 13, 2007 08:41 AM
JDM-FREAK
12
May 17, 2003 12:31 PM
