Help needed: Stock Honda CD Radio
Old Mar 10, 2003 | 06:08 PM
GorData's Avatar
Default Help needed: Stock Honda CD Radio
I have a 00 Honda cd radio and I was going to put into my 94 Integra but I have a little big problem, The plug is different, I cant get it from the dealer, What Can I do, any of you fellow honda-techer change the factory radio and have the factory blue PLUG.
Old Mar 10, 2003 | 08:09 PM
Jon Black's Avatar
Default Re: Help needed: Stock Honda CD Radio (vteccivicsi92)
You can get aftermarket plugs to fit most radios. Metra makes them. You may have to buy them online.
So what you need is the plug that goes INTO your radio ('00) and then buy a wiring adapter plug that goes into your car ('94). Solder those two adapters together and then you will have a complete adapter harness. It should cost you about $30 for the two plugs.
Otherwise call a junkyard and get them to chop out the radio harness and then buy an aftermarket harness for your car and do the same thing.
Good Luck
Jon Black
Old Mar 10, 2003 | 08:50 PM
philly-O's Avatar
Default Re: Help needed: Stock Honda CD Radio (Jon Black)
best buy or most stereo shops will have the harnesses you need.
NHBP-FA5
Mar 2, 2009 12:03 AM
Odiedogcx
Aug 10, 2004 07:38 PM
Mr Boston
Audio / Security / Video
Nov 26, 2003 06:14 AM
laughinxxx
Apr 30, 2002 08:08 AM
Black R
May 22, 2001 09:30 PM
