Fast Idle Thermo Valve on F22B1
Old Mar 10, 2003 | 06:03 PM
97accordex's Avatar
Default Fast Idle Thermo Valve on F22B1
Can someone with an F22B1/2 please take a look at this pic and let me know if the hoses are correctly connected? The fitting on the thermostat housing has a coolant hose that I think is supposed to go to the fast idle thermo valve fitting on the bottom of the throttle body.
I had my intake manifold off and forgot to label some hoses.
http://users.qnci.net/deepblue/TB.html
[Modified by 97accordex, 10:04 PM 3/10/2003]
Old Mar 11, 2003 | 03:55 PM
GZERO's Avatar
Default Re: Fast Idle Thermo Valve on F22B1 (97accordex)
my helms says is not that way
i'll try to take a pic so that you can see it, because i don't have a scaner
EDIT: pics
add .orig.jpg at the end to see them bigger
[Modified by GZERO, 8:12 PM 3/11/2003]
Old Mar 12, 2003 | 02:32 AM
niedejb's Avatar
Default Re: Fast Idle Thermo Valve on F22B1 (GZERO)
Thats how I have mine
Old Mar 12, 2003 | 06:03 AM
97accordex's Avatar
Default Re: Fast Idle Thermo Valve on F22B1 (niedejb)
Thanks niedejb. That helps a lot. Now I am not so worried about flooding my intake with coolant.
Old Mar 12, 2003 | 06:09 AM
97accordex's Avatar
GZERO,,, I have the same Helms for the 97 Accord and I looked at those schematics and could not figure out whare that darn hose goes. From the diagram, it looks like there is a tubing bracket that the hose from the thermo housing attaches to. The other end of the tubing bracket is attached to the fast idle thermo valve by another hose. (That hose bracket may be for CA emissions.)
Since I do not have that bracket with the tubing I must assume that the hose needs to plumbed from the thermo housing to the fast idle valve.
Take a look at you your motor. You should be able to see this very clearly. It would take a load off my mind to know that I am not going to be flooding coolant into my intake manifold.
[Modified by 97accordex, 10:11 AM 3/12/2003]
Old Mar 12, 2003 | 06:50 AM
GZERO's Avatar
well, it doesn't matter where you plug it, but the cicle goes from the IAC to the FITV and then i don't know where, but if you have it this way or other way around is the same
an2ny888
Sep 28, 2005 09:23 AM
THEredDEVIL
Feb 12, 2004 08:33 PM
OneThirtyEight
Oct 18, 2002 06:26 PM
93SSPHatch
Aug 3, 2002 11:06 PM
Gennady
Jan 21, 2002 04:39 AM
