EF Swap Techs Please look
Old Mar 10, 2003 | 05:48 PM
STHPERFORMANCE's Avatar
Default EF Swap Techs Please look
Mods please leave this thread in here, I think since this is the Ef forum my problems might be answered faster here then the Hybrid forum since the EF forum gets more hits
Ok Here in my problem...........................
I have a 1991 Si hatchback, I bought a 2001 LS (automatic) longblock and adapted the USDM Ys1 92-93 GSR cable tranny to it... I am using the Place racing 3 mount kit with the 90-93 integra rear mount bracket.. So we got the motor in and bolted up and wired up.. Go to fire it over and we get sparks, The crank Pulley is rubbing the radius rod badly... My car is lowered about 1 and 3/4 inchs all around. We went around and made sure all the mounts were tighten and they were. So i slapped my stock shocks in the front since i dont have the spanner wrenchs to raise the coilovers. Once i had my stock shocks in the front i took it for a ride, There seemed to be no motor movement, seemed pretty tight.
Can someone please help me? i want me car back
[B] The picture above is with the coilovers on the car and the car was lowered as i said 1 & 3/4 inchs around. Once anyone gets in the car (even my 60 pound little brother) it hits the radius rod and shoots sparks..
Old Mar 10, 2003 | 05:52 PM
Malgerus's Avatar
Default Re: EF Swap Techs Please look (Outkast)
Seems like the motor' sitting too low... obviously
Anyways, is there any clearence above the valve cover? Maybe try to shim the motor mounts up??
Old Mar 10, 2003 | 05:55 PM
Default Re: EF Swap Techs Please look (Mr. S)
What could i use to shim it ?obviously i am guessing i would wanna shim the driver side Place mount correct???
Old Mar 10, 2003 | 05:58 PM
Malgerus's Avatar
Yeah, that's what I would try. Sorry to hear about this man, I too know the pain of non working swaps... hence my signature...
crap. I just realized that this won't work! You can only lower the motor, not raise it up. You have place racing mounts, huh? Your motor should be sitting fine. Is there collision damage on the car?
Old Mar 10, 2003 | 06:00 PM
there is no accidents with my car... clean strait body
Old Mar 10, 2003 | 06:05 PM
Malgerus's Avatar
Normally I wouldn't suggest doing this, but Maybe you could grind the rod down a a little bit... (I don't know how much your motor is contacting it, so this may be a moot suggestion).
Old Mar 10, 2003 | 06:07 PM
swaplighter's Avatar
im not sure i understand..ive never seen that before. something is obviously wrong.
Old Mar 10, 2003 | 07:14 PM
Default Re: EF Swap Techs Please look (swaplighter)
I went out and took these pics few minutes ago........ maybe you guys can determine if the motor sits alittle lower on the driver side from these pics.. Thanks
Below are two pictures of the bar that the crank pulley hits
Someone Please Help Me..........
Old Mar 10, 2003 | 07:19 PM
4drEF's Avatar
Keyboard Humorist
One question - Are those Place Racing mounts?
Old Mar 10, 2003 | 07:23 PM
Fobtions's Avatar
Default Re: EF Swap Techs Please look (4drEF)
get a ctr crank pulley, or cut the one you have and balance it.
Old Mar 10, 2003 | 07:26 PM
Default Re: EF Swap Techs Please look (Fobtions)
yes they are Place Racing mount kits as i have listed at the very top of this thread.... Also, are you 100% sure a ctr pulley will work cause 145 bucks is a stabb in the heart for something that wont work....
Old Mar 10, 2003 | 07:30 PM
Redline130's Avatar
Very perplexing. It's kinda hard to tell from those pics if the motor is sitting level in the engine bay. Maybe if you took one looking "head on" with the car, then maybe an angle could be seen. I've had a B18A in my CRX, and it had a least 1.5" of clearance from the radius rod. But I had custom mounts made, so that could be a difference. Interesting....
Edit: After looking at the pics again, the motor seems to positioned a bit more forward than other B-series swaps I've seen. Maybe it's just me. Seems like you have a lot of room between the firewall the the intake manifold. I think if the motor was a bit more back toward the firewall, the pulley might clear the radius rod. Again, it might just be me misinterpreting the pics.
[Modified by Redline130, 8:35 PM 3/10/2003]
[Modified by Redline130, 8:38 PM 3/10/2003]
Old Mar 10, 2003 | 07:32 PM
keebler65's Avatar
that was my thoughts as well. actually, i remember reading a topic like this awhile back but i dont know if it was yours or not. but i remember the idea of the CTR pulley being tossed around. i guess it depends on where its hitting. as far as how low the engine is, you might have to take more pics. the current ones you have dont help much for depth perception since our monitors are 2D. try taking a "sea level" pic just above the fender, if that makes sense.
Old Mar 10, 2003 | 07:37 PM
shortyz's Avatar
Default Re: EF Swap Techs Please look (keebler65)
it looks to low on that side to me..
how much does it hit.. like is it only just touching or pressing right on it..
Old Mar 10, 2003 | 07:39 PM
xjoe's Avatar
hahaha, nice radiator overflow can
Old Mar 10, 2003 | 07:45 PM
keebler65's Avatar
Default Re: EF Swap Techs Please look (xjoe)
yeah until it melts from the combined heat of the radiator, exh mani, and block...
whatever works though
Old Mar 10, 2003 | 07:50 PM
Cvic90's Avatar
One question? I'm just wondering why your using the newer engine mount on the driver side? I thought the 90-93 mount is supposed to be used with the EF kits. My HAsport Billet kit uses it. Could that be a problem? Although it does look like it is made to fit by looking at the pics. Look under the car to see if the oil pan is tilted toward the driver side. Mount postion is lower because of it. I've lowered my car about 2.5-3" in the front and don't have a problem. And my front end is to far back because of a wreck, I didn't notice to pull it forward. Check the mounts, If the car is straight, must be a mount problem to me.
Old Mar 10, 2003 | 07:54 PM
the soda bottle is temporary duh, i have the regular oem bottle sitting aside the car. As far as the other pics you guys requested, here they are.....
A friend of mine brought up about the 90-93 Integra side engine mount bracket that bolts to the Place mount, i have the Place racing BIM04 kit and i was told i didnt need to change the oem 2001 LS side mount on the motor... Could that possibly be my problem?
Welp here are the pics....
Old Mar 10, 2003 | 08:01 PM
keebler65's Avatar
man its hard to say, but it looks like its about where it should be. although its possible to be off just enough to rub but not for our eyes to notice it.
Old Mar 10, 2003 | 08:22 PM
Magick211's Avatar
What driver side mount bracket are you using? I think your suppost to use the 90-93 teg driver side mount bracket you know the bracket that the actual motor mount bolts onto?
Old Mar 10, 2003 | 08:26 PM
Default Re: EF Swap Techs Please look (CivicBoyZC)
I am using the stock 2001 LS side mount bracket cause i was told the new BIM04 kit from place racing i didnt have to get the 90-93 side mount bracket....... That person who told me that could be wrong though.......
Old Mar 10, 2003 | 09:25 PM
To the top for the night crew......
Old Mar 10, 2003 | 09:58 PM
customx_'s Avatar
New User
your first mistake was using Placing racing mounts
Old Mar 10, 2003 | 10:37 PM
ThatRicerDaniel's Avatar
my freind had the same problem .. he just got a after market pulley and eventually got rid of the place racing mounts and got hasport.
Old Mar 10, 2003 | 10:50 PM
iwouldHITit's Avatar
Default Re: EF Swap Techs Please look (NitrousDreamz)
i had the same problem.. i have the same setup too with placeracing..
what i did was get an aftermarket pulley...i dont know what brand it is cause i bought it use but it is silver...and it can only hold the alternator belt so no ac belt...i will try and get pics...
[Modified by iwouldHITit, 7:52 AM 3/11/2003]
