timing & alternator belts
loosen the alternator bolts, and push it back, thereby tightening the belt tension. While you're pushing it as tight as yuo want it to be, tighten the bolts up.
As for the timing belt, search. If you can't tighten an alternator belt, I WOULD NOT reccomend you try to do your timing belt. Get it done professionally.
Jayboy
Jul 25, 2005 10:56 AM
DohcRex
Jan 5, 2003 12:07 AM
