Smog techs or anyone else please help....
Old Mar 10, 2003 | 04:37 PM
bleebdat's Avatar
Default Smog techs or anyone else please help....
My car is consistently failing smog, I now have it passing on HC and CO, but it still fails on the NOX. Not just by a little either, the readings are almost 2000 and u need to be below 800. My setup is z6 block, y8 head, obd-0 91 si ecu, obd-0 si dizzy, new cap, new rotor, new 9.3 mm wires, and bosch +2 platinum plugs. Could the cat be causing such a high NOX #, it is about the only thing I havent changed yet. Please any advice is greatly appreciated.
Old Mar 10, 2003 | 04:41 PM
deepnite's Avatar
Default Re: Smog techs or anyone else please help.... (bleebdat)
this all so new to alot of us with the new dyno testing..have u had ur car diagnoist as to what the problem is?
Old Mar 10, 2003 | 04:51 PM
bleebdat's Avatar
Default Re: Smog techs or anyone else please help.... (deepnite)
I have not had it diagnosed yet, that costs 60 roughly and was looking to fix it myself. I searched all over the web, but most sites when talking about NOX only mentioned problems with EGR(exhaust gas return) I have no problem with my EGR being that there was never an EGR on my car.
Old Mar 10, 2003 | 07:16 PM
bleebdat's Avatar
ttt
Old Mar 10, 2003 | 08:09 PM
Creamies's Avatar
NOX from what i understand is caused by high compression. To reduce the NOX output from the exhaust is to get a new cat. I heard of a guy runing high compression and had a mustang 5.0 cat on his honda and it passed.
[Modified by Creamies, 9:09 PM 3/10/2003]
Old Mar 10, 2003 | 08:44 PM
bleebdat's Avatar
Default Re: Smog techs or anyone else please help.... (Creamies)
Thanks Creamie, I just put a new cat on today so we shall see, a little off topic, but can 2 cats one after the other significantly help?
Old Mar 10, 2003 | 08:48 PM
redzcstandardhatch's Avatar
something different
two good condition cats isnt a bad idea if you dont pass with one......dont just add another after the old shitty one though, that will help, but exhaust flow will be significantly impared around the cat-region...i just went to pep-boys and bought the biggest cat i could find in the back......2.5 inch like my exhaust, and my car passed on the third try.....the guy just tried a few times, he missed a shift once, so he said that failed it......silly illinois dude's not knowin how to drive a stiff cable clutch
Old Mar 10, 2003 | 11:13 PM
bleebdat's Avatar
Default Re: Smog techs or anyone else please help.... (redzcstandardhatch)
Thanks for the help guys, Im going in tomorrow with the new cat...
Old Mar 10, 2003 | 11:57 PM
Creamies's Avatar
good luck let me know how you did, im intrested if that was enough to gget it passed.
Old Mar 11, 2003 | 06:30 PM
bleebdat's Avatar
OMG the focker passed!!!!! With the new cat it barely burped out any HC, CO, and NOX at all. Im so happy!
Old Mar 12, 2003 | 12:53 AM
Creamies's Avatar
WillingEK
May 8, 2018 10:38 AM
24TEN
21
Oct 3, 2012 08:21 AM
ITRex
Jun 9, 2008 07:30 AM
Edulerp
Jul 15, 2006 02:48 PM
sohc90rex
16
Mar 31, 2005 07:27 PM
