Code 43 (Fuel Supply System defective or malfunctioning fuel supply system)
Old Mar 10, 2003 | 02:05 PM
95c1v1cs1's Avatar
Default Code 43 (Fuel Supply System defective or malfunctioning fuel supply system)
I have been getting this code every once in awhile. I am just trying to figure it out before my car gets turboed. Anyone got ideas what the problem could be???
Corey
Old Mar 10, 2003 | 02:32 PM
Chiovnidca's Avatar
Default Re: Code 43 (95c1v1cs1)
The first thing to check is fuel presure. Is it within spec?
Old Mar 10, 2003 | 08:54 PM
95c1v1cs1's Avatar
Default Re: Code 43 (D16Chiovnidca)
I was a bit broad on the first post. Here is my Fuel Setup. Jackson In-tank Fuel Pump, AEM FPR, AEM Rail, V-AFC, and Gauge. My fuel is set at 55psi at idle. Spec is 47-52 i am pretty sure. I have a 94 B18c1... Anyone???
Old Mar 10, 2003 | 10:30 PM
BR's Avatar
BR
99.9% of the time code 43 is a faulty O2 sensor. Replace it and the problem should go away after you reset your ECU.
Later,
BR
Rhythmsnewsn
Sep 4, 2006 03:30 PM
89 CRX SI
Apr 22, 2003 03:22 PM
oO
Apr 10, 2003 07:03 AM
blackcracker
Oct 25, 2002 06:13 PM
