disc conversion on a 4th gen
Old Mar 10, 2003 | 10:42 AM
rage237's Avatar
Default disc conversion on a 4th gen
i am getting a 90 honda accord i have a 91 right now as far as i know they are the same.. my question is can i take the rar disc's off of a 92-93 accord and put them on the 90?? or does the 90 already have disc's in the rear?? if not how hard would it be to convert??
Old Mar 10, 2003 | 10:44 AM
rodpod's Avatar
Default Re: disc conversion on a 4th gen (rage237)
my 90 accord lx has drums in the rear
Old Mar 10, 2003 | 12:31 PM
Starrman85's Avatar
Default Re: disc conversion on a 4th gen (rodpod)
i have a 92 ex, and i have disc in the rear. as far as i kno, the 92-93 accord EX has disc in the rear...i believe the 90-91 EX does as well, but if not, i would think it's be a pretty easy swap, but as for hooking up the calipers, i dunno how you would go about that.
Old Mar 10, 2003 | 12:43 PM
cyrixvsp2's Avatar
Default Re: disc conversion on a 4th gen (STARRMAN85)
90 and 91 doesn't have disk rear. it's an easy swap though. someone on the board has already done it. i'm goign to do it soon.
Old Mar 11, 2003 | 06:43 PM
k-mart's Avatar
Default Re: disc conversion on a 4th gen (cyrixvsp2)
doesn't the 91 SE have discs?
Old Mar 11, 2003 | 06:45 PM
Martaigne's Avatar
Just get the rear trailing arms, calipers, and rotors off an EX.
Old Mar 11, 2003 | 06:54 PM
slomofo's Avatar
GDD Member
It's probably the same as my civic hatch swap. Take the rear trailing arms/hub assemblies and brake lines. You might run into a problem with the brake lines seeing that drum brakes use a metal line that runs into the wheel cylinder and disc brakes use a rubber hose with a brass eye fitting bolted to the caliper. With my brake lines, I took the rubber hose from the disc brakes and connected it to my metal line. Parking brake might give you some problems too.
Old Mar 12, 2003 | 05:10 AM
Kwisatz Haderach's Avatar
Default Re: disc conversion on a 4th gen (slomofo)
The '93 SE has rear discs, but I dunno if you'll be able to find one thats junked. I haven't even seen that many of them on the road.
Old Mar 12, 2003 | 12:23 PM
KoKreation's Avatar
Default Re: disc conversion on a 4th gen (k-mart)
yeah they do
Old Mar 13, 2003 | 06:47 AM
rage237's Avatar
Default Re: disc conversion on a 4th gen (PiNg~PiNg)
Thanks guys all your help is greatly appreciated, i will be posting the rebuild of the 90 accord on the fourm soon. and i might be parting out my 91 so give me a holla thanks
Old Mar 13, 2003 | 07:12 AM
pwrd_v_tec's Avatar
Yeah you can do it but I would rather go with the legend rear discs. (larger)
Old Mar 13, 2003 | 07:13 AM
rage237's Avatar
Default Re: disc conversion on a 4th gen (pwrd_v_tec)
how hard is that??
what would i need??
Old Mar 14, 2003 | 09:40 AM
pwrd_v_tec's Avatar
Go over to the HS board or he could be here too. His name is bustedlx. But from my understanding everything bolts right up. He's is about to do it and I know there at least 3 people that have done this over there.
Old Mar 17, 2003 | 08:10 AM
JDM_CD7's Avatar
You can just use the setup for a 91 SE to do the Rear Disc swap...
Mines is coming along next month i'll post some pics up for you
Old Mar 19, 2003 | 02:39 PM
rage237's Avatar
Default Re: disc conversion on a 4th gen (JDM_CB7)
those are hard to come by were im at (washington state)
i am having a hard enough time getting stock fenders for the car
Shwilson
Suspension & Brakes
Sep 23, 2011 08:00 PM
1990AccordEX
Apr 2, 2006 02:26 PM
chronic4dr
Apr 15, 2005 01:47 PM
B18C5EK
Dec 7, 2002 06:32 PM
