Zdyne question + 89 Teg ECU
Old Mar 10, 2003 | 09:36 AM
CWBETB's Avatar
Default Zdyne question + 89 Teg ECU
Hey guys Im going for the Zdyne Gold ECU for my Turbo ZC setup. I just called Zdyne and the way they put it its a $50 addition charge for the clutch cut feature? Also is a 89 Teg ECU considered PR4?
Old Mar 10, 2003 | 09:40 AM
zCivic's Avatar
Default Re: Zdyne question + 89 Teg ECU (CWBETB)
No PR4 is 90-93 teg ECU either OBD0 or OBD1. Your 88-89 teg ecu is a PG7 or PM7. Take the top cover off and on the green plug will tell you what it is for sure. Alot of people take them out of the funky cases and place them into 88-91 cases so can be bolted in with the cover. Thats why I didn't suggest the sticker on the side
[Modified by zCivic, 1:42 PM 3/10/2003]
Old Mar 10, 2003 | 11:07 AM
Speed PHreak's Avatar
Go find an HF ECU, I talked to Bill a while back when I got mine and he said that they acutally like the HF ECU's better. They have more circuitry in them than the other obd-0 ecus(due to the shift light and other misc electronics). You can usually pick them up at a junkyard or from friends for cheap 'cuase nobody wants them.
[Modified by Speed PHreak, 3:07 PM 3/10/2003]
Old Mar 10, 2003 | 11:37 AM
one slow d16's Avatar
Default Re: Zdyne question + 89 Teg ECU (Speed PHreak)
yea, checkt he local shop or even the dumpster behind the shop
Old Mar 10, 2003 | 11:46 AM
CWBETB's Avatar
I looked over the site again and it seemed like some ECU's are additional Fee for clutch cut.
Im hoping somone can score me a HF or Si ECU for dirt cheap
driftam1
Oct 27, 2008 02:43 PM
Red_Si
Jul 11, 2002 07:34 AM
USDM 4G VTEC
May 13, 2002 06:00 AM
USDM 4G VTEC
May 13, 2002 05:59 AM
civic2299
May 11, 2002 11:31 PM
