Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
How much camber to add?
Old Mar 10, 2003 | 06:15 AM
ryan12321's Avatar
Default How much camber to add?
I was doing taking some temperatures yesterday at an auto-x trying to figure out if i need more camber. I have -1.3 right now and 0 toe. My temps were about 105-110 on the inner edge, 115-120 in the middle, and about 125-128 on the outer edges. So the temps show they were consistently getting hotter toward the outside. I really haven't read too much into what changes effect what but i figured some of you guys might know.
thanks
Old Mar 10, 2003 | 07:15 AM
Todd00's Avatar
I said I don't want a title!
Default Re: How much camber to add? (ryan12321)
- What kind of car?
- Was this front or rear tire temps?
- What brand of tires?
- What Suspension?
Sorry for all of the questions, but different setups dictate different answers.
Old Mar 10, 2003 | 07:30 AM
ryan12321's Avatar
Default Re: How much camber to add? (Todd00)
- What kind of car?
- What Suspension?
oops, forgot about all that.
00 si
41/38 tire pressures
those are front temps because i didn't measure rear thinking i'm not going to change anything back there
350/400 on kyb agx, 22mm sway, about 1.5" lowered
and yokohama es100's, but i could go to falkens again, still deciding.
Old Mar 10, 2003 | 08:58 AM
solo-x's Avatar
just curious, what was the ambient air temp? i would love to have tire temps that low. last year the falkens would routinely see 140+ temps.
nate
Old Mar 10, 2003 | 10:48 AM
ryan12321's Avatar
Default Re: How much camber to add? (solo-x)
it was around 65 i think. during the summers last year my falkens would get so hot i couldn't even touch them with my hand even after trying to cool them down with water. But that was with about 95 degree outside temps.
Old Mar 10, 2003 | 11:00 AM
Catch 22's Avatar
For you Ryan, +1.5 degrees on both sides would be good.
Seriously, we're running -2 up front on the Neon and things look pretty good.
Old Mar 10, 2003 | 12:14 PM
Todd00's Avatar
Default Re: How much camber to add? (Catch 22)
On a gen 6 Civic, I'd consider no less than 2degrees in the front, and the rear no more than 1.5 or so.
Old Mar 10, 2003 | 03:58 PM
ryan12321's Avatar
I'll probably end up around 1.6 or so. I only plan on changing it by ride height since I don't want a camber kit. I have the F/R camber ratio I like so both front and rear will increase at the same time. I just have to get the time to go home and lower it and then put it on the alignment machine.
Old Mar 10, 2003 | 04:05 PM
MattG's Avatar
New User
How much is your car lowered? I am trying to figure out a ratio of lowering to camber.
Old Mar 10, 2003 | 04:56 PM
ryan12321's Avatar
Default Re: How much camber to add? (MattG)
I would guess about 1.5". I'll try and go out and measure from ground to fender for you tommorow. I have the rear corrected so that front and rear are the same though.
Old Mar 10, 2003 | 05:24 PM
Catch 22's Avatar
A good rule of thumb for this chassis is .8 degrees - camber for each inch lowered.
Same for 3rd gen Integras.
Old Mar 10, 2003 | 06:40 PM
Todd00's Avatar
Except in the rear. The 6th gen Civic redid the control arms and the camber curve gets bad in the rear when lowered. 6th gen civic is different than the 5th gen and the 3rd gen teg.
And, the ITR is a tad different too because of the rear control arms.
rear camber = understeer.
[Modified by Todd00, 10:41 PM 3/10/2003]
VTECROAR96typeR
Suspension & Brakes
Apr 4, 2010 10:11 AM
Ron M
Apr 3, 2008 06:33 AM
kcem1
Suspension & Brakes
11
Oct 27, 2005 03:34 PM
TunerN00b
Aug 9, 2005 07:45 PM
Racerage1
Jun 14, 2003 11:33 PM
