engine will not start?
Old Mar 9, 2003 | 09:52 PM
crxdevelop's Avatar
Default engine will not start?
My crx died today when i was driving it. i was in 4th gear when it all of a sudden it just died. i pulled off the road and tried to start it up again. all it did was crank for about 10 seconds, then started for a second, and then died right away. it is not throwing any codes and doesn't have a check engine light. my engine is a dohc zc w/an integra ecu. i had this problem in the past where my zc just died. i ended up have to put a new distributor assembly in it to solve the problem. has anyone heard of a zc starting up and then dieing right away? can anyone give me any leads on to what could be wrong? thanks.
by the way, about an hour before it died i was driving pretty fast in the mountains. also, i live in colorado and lately the weather has been going from 0 degress F to 50 degress. could this cause my coil or ignitor to go bad?
Old Mar 9, 2003 | 10:52 PM
M-EJ1's Avatar
Default Re: engine will not start? (crxdevelop)
Check your grounds, specifically your ECU ground. I just had this EXACT problem today (I admit it could be caused by a lot of things) at an autocross and it turns out that my ground wire to my ECU basically fell apart at one of the solder joints where I wired in my VAFC.
Good luck man.
Old Mar 10, 2003 | 06:06 AM
crxdevelop's Avatar
Default Re: engine will not start? (M-EJ1)
would my check engine light come on if my coil or ignitor went bad?
Old Mar 10, 2003 | 12:32 PM
crxdevelop's Avatar
the screw that holds the rotor onto the shaft fell out. all it least it was just a small problem and didn't cost any cash.
danfine
25
Jan 18, 2012 01:40 PM
o0Jash0o
Jun 1, 2008 07:51 AM
b17 turbo
May 7, 2008 11:28 PM
crxdevelop
13
Mar 11, 2003 10:32 AM
02WRX
Jul 6, 2001 12:05 PM
