Compression Check questions. Check out my numbers? JDM GSR b18c
Old Mar 9, 2003 | 07:17 PM
Reilly's Avatar
Default Compression Check questions. Check out my numbers? JDM GSR b18c
#1 - 198
#2 - 195
#3 - 195
#4 - 185, but the battery does on the this one. We are charging the battery. It might be higer.
We haven't installed the motor in the car. It's sitting on the ground. After pulling on of the spark plugs 3 of them had a lot of oil and buildup on them.
The motor was bought at HMO.
How do the compression numbers look for a b18c w/ 10.6:1 compression?
Old Mar 9, 2003 | 07:40 PM
SSBP DC2's Avatar
Default Re: Compression Check questions. Check out my numbers? JDM GSR b18c (Reilly)
you need to set the throttle at WOT. also, you're suppose check for compression when the motor is at NOT, but i don't see how you're going to warm it up with it sitting on the floor
for ref, my 98 b18c1 was 235-240
Old Mar 9, 2003 | 08:26 PM
RyanAutry's Avatar
Default Re: Compression Check questions. Check out my numbers? JDM GSR b18c (SSBP DC2)
Nope, it wasn't hot.
But we did re-check after the battery was charged.
211 210 210 211
We did have the Throttle body open. . .
Old Mar 10, 2003 | 10:55 PM
Reilly's Avatar
Default Re: Compression Check questions. Check out my numbers? JDM GSR b18c (RyanAutry)
up
97EXB18C
May 23, 2009 11:08 PM
Mugen112
Dec 28, 2005 12:48 AM
BumpinVTEC
Nov 21, 2004 10:31 PM
RyanAutry
Mar 15, 2003 01:56 PM
VTEC-DA
Jan 6, 2003 05:48 PM
