just did my b16 timing........car backfires
Old Mar 9, 2003 | 04:46 PM
type Gendy's Avatar
Default just did my b16 timing........car backfires
I finally did the timing on my crx this weekend, after doing the swap a month ago... It was pretty far off, but ran fine. So the car is timed now and backfires more than it did before, especially at high revs and vtec.... what gives??
Old Mar 9, 2003 | 06:10 PM
HybridFiend's Avatar
Default Re: just did my b16 timing........car backfires (sick hatchem)
Did you jump the service connector, when doing your base timing? If that's correct then what has been modified? Was the previous time setting retarded a few degrees?
Old Mar 9, 2003 | 06:12 PM
type Gendy's Avatar
Default Re: just did my b16 timing........car backfires (HybridFiend)
NO i didnt jump the service connector.
The previous timing was advanced as far as it would go....
Old Mar 9, 2003 | 06:51 PM
There you go... jump the service connector, make sure the car is at normal operating temp, and at a normal idle. Then make your timming adjustment.
Old May 14, 2008 | 12:07 PM
jdmb16ef8's Avatar
Default Re: just did my b16 timing........car backfires (type Gendy)
when making an ignition timing adjustment do i move the dizzy with the car on or off??
Old May 14, 2008 | 12:29 PM
traxxasx's Avatar
Default Re: just did my b16 timing........car backfires (jdmb16ef8)
No the car has to be one, thats the only way you can get the timing light on the crank to set it at 16*.
TIming light connects to + and - on the battery and number 1 spark plug wire.
StupidSlowRSX
Feb 21, 2008 10:35 PM
mortificationrock
17
Jul 29, 2007 10:57 PM
Jmumblez2001
Nov 3, 2006 01:36 AM
bazookatooth
Apr 23, 2005 11:56 PM
91sihatchback
Jun 29, 2003 05:50 PM
