bmw handling - relocated
Old Mar 9, 2003 | 04:43 PM
HuskerHybrid's Avatar
Default bmw handling - relocated
what makes a bmw so special in its handling and suspension characteristics? what specific components make it that much better than hondas/acuras? is there anyway to get similar or relatively similar handling/suspension on ours? i'm looking for a "premium" set-up.
Old Mar 10, 2003 | 09:11 AM
martini's Avatar
Default Re: bmw handling - relocated (HuskerHybrid)
It's a front engine/rear drive, with 50/50 weight distribution to start.
Here's what I found on the M3 suspension
Front suspension
Single-joint spring-strut axle with displaced camber; small positive steering scrub Radius; compensation of traverse forces; anti-dive
Rear suspension
Central-arm axle with longitudinal control arm and double track control arm; anti-squat; anti-dive
Old Mar 10, 2003 | 10:51 AM
sbourg's Avatar
Get a Honda 2000. Once you remove the drive axles from the front, you can do wonders with suspension geometry up there, as well as avoiding torque effects. Since the rear doesn't steer much, driving those wheels doesn't hamper handling characteristics. Although you can get good numbers on a track with fwd, you can't make it 'feel' like rwd.
Note as a breed German cars tend to stiffer front and softer rear spring and shock rates than the Japanese or domestic product. You might take a stab at copying a VW/Audi.
Steve
Steve
fryman
Suspension & Brakes
24
Dec 8, 2009 10:07 PM
suspendedHatch
Suspension & Brakes
Apr 18, 2006 09:27 PM
Mr.E.G.
Suspension & Brakes
116
Nov 15, 2005 11:31 AM
manman
Oct 19, 2005 07:30 PM
slowcivic
Apr 17, 2003 10:04 AM
