Will a Type R LSD fit my JDM YS1 cable tranny?
Old Mar 9, 2003 | 01:39 PM
E-lude78's Avatar
Default Will a Type R LSD fit my JDM YS1 cable tranny?
There are so many Type R LSD's for sale on Ebay and its tempting to buy.
Old Mar 9, 2003 | 02:35 PM
SiR Kid's Avatar
New User
Default Re: Will a Type R LSD fit my JDM YS1 cable tranny? (Mista B-one-seven)
Only the CTR LSD will fit. The ITR LSD is a larger diameter, and the CTR uses the smaller diameter that works in Cable trannies, LS trannies, and the 92-93 GSR transmission.
HTH.
Old Mar 9, 2003 | 03:23 PM
JDM_DOHC_SiR's Avatar
New User
Default Re: Will a Type R LSD fit my JDM YS1 cable tranny? (SiR Kid)
HTH.
Ummmm ...Wrong!! ITR/CTR same Part Number Gus'
and they will both fit you just have to mate up the right diff ring..
Old Mar 9, 2003 | 05:07 PM
Spaceballsthelunchbox's Avatar
No Big Whoop
Default Re: Will a Type R LSD fit my JDM YS1 cable tranny? (JDM_DOHC_SiR)
I have asked the same question on different forums and I am always told it won't fit. Do you have first hand experience with this? have you installed a CTR or ITR LSD in a Y1, S1, J1 or YS1?
Thanks
Old Mar 9, 2003 | 05:28 PM
E-AT_me's Avatar
Default Re: Will a Type R LSD fit my JDM YS1 cable tranny? (Spaceballs the lunch box)
it's been done.. here's how..
http://courtneyeg9.streetracing.org/btech.trans.y1.html
Old Mar 9, 2003 | 07:10 PM
smokey2.0's Avatar
Default Re: Will a Type R LSD fit my JDM YS1 cable tranny? (Rexman)
i was thinking of doing that same set up, but with a usdm ys1 mainshaft & counter shaft. usdm itr 2/3/4, with a 92-93 ys1(gsr) fd ring gear on the ys1 differential(or itr lsd if i can get one for a reasonable price). i have all the parts, except for the gsr fd ring gear wich i got to get at the dealer! so i'll have ls 1(actually gsr with the 4.40 fd), itr 2/3/4, and ls 5th wich should be a touch slower than a gsr fifth! i hope it works, since is all theory at this point!
Old Mar 9, 2003 | 09:46 PM
E-lude78's Avatar
Default Re: Will a Type R LSD fit my JDM YS1 cable tranny? (smokey2.0)
What happens if you change the FD? Higher number FD = higher revs at highway speeds?
Old Mar 10, 2003 | 03:48 AM
No Big Whoop
so, can you just put the LSD without changing the shafts and gears?
I like the gearing on my Y1, and don't want to play with final drive gears and custom gearing.
Old Mar 10, 2003 | 09:15 AM
CRX-RX's Avatar
I'd like to know how the GSR/ITR bearings are even remotely close, because they're not at all, aside from being sealed roller bearings, that's it. They are different sizes. Also how do you fit the 92-3 YS1 ring gear on the R lsd, the housing and ring gear of an R lsd are physically larger than the YS1, and for you to be able to put the ring gear of a YS1 on the R you would have to have the inside edge machined out to fit (which there is no way in hell I want that in my trans! Kind of like having wheels without the center fiting snugly around the hub ring, ok for wheels, bad in trans). Then the case of the R lsd is larger diameter then the YS1, it's possible this could fit, I have never tried, but it doesn't look promising looking at the two side by side.
Old Mar 10, 2003 | 04:43 PM
New User
Thanks
Sure have... Who do you think gave hime that information on his site
-Dave
Old Mar 10, 2003 | 04:49 PM
New User
If thats the case then you cant use the ITR LSD it will only work with the 98Spec or 96 Ring gear
-Dave
sogtulakk
Aug 28, 2005 02:33 PM
hondalude89
Aug 23, 2005 09:33 AM
7rrivera7
Feb 21, 2003 03:22 PM
ZERO COOL
Jan 27, 2003 12:58 PM
