Charge piping/welding costs?
Old Mar 9, 2003 | 12:03 PM
tylerdurden's Avatar
Default Charge piping/welding costs?
I'm new to turbos, and I'm thinking of doing a junkyard turbo (T25) on my CRX Si. I've done some research on what it takes, but I see there is quite a bit of welding needed for such a custom job (BOV flange, custom downpipe, charge piping, oil pan return) and I can't weld. What is such a job likely to cost at a good muffler shop? I'm talking about all the piping from the turbo to the intercooler to the TB (including the BOV flange welding), and the downpipe and a full exhaust. I'm thinking probably $500+. Am I wrong?
EDIT: As a related question on the BOV, on Honda's where is the MAP sensor located? I'm pretty sure it is not before the intake piping (acutally, quite sure), so is it bad to vent the BOV to the atmosphere (as in, not likely to cause rich-run conditions)?
Also, where are the check valves supposed to be located to prevent the CEL?
Sorry for the noob q's, I didn't have much luck with my searching. Please feel free to direct me elsewhere.
[Modified by tylerdurden, 9:08 PM 3/9/2003]
Old Mar 9, 2003 | 02:11 PM
Trac226's Avatar
Default Re: Charge piping/welding costs? (tylerdurden)
I had my my type-s flange nicely fishtailed onto my charge pipe for $40.
Old Mar 9, 2003 | 02:16 PM
Default Re: Charge piping/welding costs? (Trac226)
Anyone know what the entire job might run me? I know there are people here running custom fabbed systems.
Old Mar 9, 2003 | 02:20 PM
b18bturbo's Avatar
its about 400 complete with stainless piping usually
Old Mar 9, 2003 | 03:49 PM
mamaboy's Avatar
Buy one of those cutoff machines from Sears or Home Depot. The cheapest one should do and just take a day and cut your mandrel pipes. Pipes should run you over $50. JC Whitney is the magical word. get some clamps and rubbers and have a fun weekend filled with beer, pizza, and friends....
Old Mar 9, 2003 | 05:50 PM
Default Re: Charge piping/welding costs? (mamaboy)
Would using individual pieces of pipe with silicone/rubber connectors be much worse than welding them together?
Flamenco-T
Jun 7, 2006 02:46 PM
ringgold
Welding / Fabrication
24
Nov 29, 2004 12:13 PM
sung
Jun 22, 2003 09:57 PM
blufke
Sep 24, 2002 10:56 PM
