Si head question ? 56k warning !
Old Mar 9, 2003 | 06:41 AM
plonger's Avatar
Default Si head question ?
Is it normal to have brown valve ? Because the head was stored in the three last month ? http://home.1asphost.com/plonger/si-head.jpg
[Modified by plonger, 3:42 PM 3/9/2003]
Old Mar 9, 2003 | 07:47 AM
Hondasaurs's Avatar
Default Re: Si head question ? (plonger)
It looks like, at one point in time, your head gasket was bad. That is burned up anti-freeze on your valves. You may even have a cracked head. Thats how mine looked when my head cracked.
Old Mar 9, 2003 | 07:52 AM
plonger's Avatar
Default Re: Si head question ? (ZC_CRX)
The gasket was brand new but the block blow up because of an ghetto rebuilt . I hope the head is still good
Old Mar 9, 2003 | 07:54 AM
Hondasaurs's Avatar
I'd suggest taking it to a shop and getting it tested.
Old Mar 9, 2003 | 01:11 PM
plonger's Avatar
With what i can clean the overall head ?
thanks ! a few more pics :
http://home.1asphost.com/plonger/si-head4.jpg
http://home.1asphost.com/plonger/si-head5.jpg
http://home.1asphost.com/plonger/si-head6.jpg
http://home.1asphost.com/plonger/si-head7.jpg
[Modified by plonger, 10:17 PM 3/9/2003]
Old Mar 9, 2003 | 02:07 PM
Hondasaurs's Avatar
I cleaned the valves with a Dremmel with a wire brush then polished them so they were smooth.
Old Mar 9, 2003 | 02:40 PM
USDM 4G VTEC's Avatar
what the **** happened to the gasket surface of that head??
did u sanded that?????
u only use a sharp razor.... that might take the seal off the gasket, making an uneven seal.......... maybe a leak that messed ur head up...
but other than that take the head to a machine shop
they will be able to tell u whats that caused by..dont take peoples opinions here... its hard to tell by jsut a pic.... u gotta check the roufness and all that......
Old Mar 9, 2003 | 02:56 PM
Hondasaurs's Avatar
Default Re: Si head question ? (USDM 4G VTEC)
Its obvious that he cleaned all the head gasket material off in the 1st pic.
I always thought we used this forum to post opinions and help trouble shoot a problem.
Besides the nonsence, take the head to a shop and get it pressure tested.
Old Mar 9, 2003 | 03:03 PM
sorry if it sounded bad against us
i have helped a lot of people... and i have been helped a lot of times
what i ment its that on that spceific case, in wich he has a picture of valves wich are abou 1.5 inches.... at a distance.... its very hard to predict whats the cause of that discoloration, just wanted to say to take it to profesionals....
Old Mar 9, 2003 | 03:08 PM
Hondasaurs's Avatar
Right on! Thats what need to be done.
Old Mar 10, 2003 | 12:46 PM
plonger's Avatar
right ! i will take the head to a shop . Here is a pic of the valve after cleaning !
http://home.1asphost.com/plonger/valve.jpg
Joker_God
12
Nov 30, 2009 01:34 PM
cBrown05
Oct 9, 2009 07:48 AM
EH-3
Jun 19, 2006 09:36 AM
EJ8 GSR-T
Jan 24, 2006 07:10 PM
