1st dyno run!!!
Finally I got the chance to get my R strapped to the rollers! 180.1 hp, 129.5 ft.lbs. of torque. AEM c.a.i., DC JDM 4-1 header, test pipe, Apex N1 catback, 10.3 MM OBX plug wires, NGK plugs-1 heat range cooler. Timing @ 20 deg. BTDC. I thought it was pretty good for 70 degrees & about 80% humidity. WOOOOOHOOOOOOOOOOO!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
I am calling BS on this one until you prove it w/ the graph.
It is possible these numbers are correct but without a graph I cant be sure. I trust that most people in the ITR forum are all stand up guys and wouldnt lie about dyno numbers. It would be nice to see a graph to check out the curve since most of us know that peak horsepower isnt the most important number when looking at an ITR's performance. I will be glad if it is true cause lately numbers on here have been pretty low. I havent had a chance to get a base number for my stock ITR so seeing low numbers with a few good mods have steered me away from getting it done since to me (my butt dyno) the car is making good power. kudos to you and your good numbers.
[Modified by ITR-862, 9:23 AM 3/9/2003]
all dyno's put out different numbers. The ones down at DSR have numbers lower than most, but they are consistent. I have more mods than this guy and made 169 peak with a nice and smoothe midrange. Some dyno's have bone stock R's putting out 170's to the wheels, so I am not suprised.
but the curve looks werid... some kind of boost there
George's Car: Below is the Dynojet dyno plot of the car in its current configuration. (Comptech Icebox, JDM OEM header, Carsound Cat, SMSP 2.5" exhaust)
First & foremost I have no reason to lie about a dyno run. I am a Christian & lying isn't goin to be an issue with me. I'm just thankful I fianally got the opportunity to do this. If you give me a day or so I'll get the graph up. I gotta use a friends comp. cause I don't have the scanner to do it with.
I say you get a VTEC controller and make your power band a bit smoother. I think that would be the smart thing to make for your next mod
J/K George.. (on the pops comment.)
