b series rod bearing size's
Old Mar 8, 2003 | 07:31 PM
UncleBen'sRacing's Avatar
Default b series rod bearing size's
anyone know what size's the rod bearings are? i have RED ones but they are a bit too large, so i need smaller they go RED, Pink, yellow, green from largest to smallest, (thinest to thickest)
anyone know what size's they are... the plastic guage reading is beyond factory spec, i donot believe it is past the service limit of .050, is there anything i can do in order to not turn the crankshaft, i know that honda makes bigger bearings, but are any of them significantly larger?
[Modified by AllMotorEF9, 8:38 PM 3/8/2003]
[Modified by AllMotorEF9, 8:40 PM 3/8/2003]
Old Mar 8, 2003 | 09:14 PM
earl's Avatar
Default Re: b series rod bearing size's (AllMotorEF9)
Not sure what you are asking for so will post this:
Honda bearing colors:
Blue (thickest)
Black
Brown
Green
Yellow
Pink
Red (thinest)
The thicker the bearing, the smaller your clearance will be.
Each color step is .003mm or .0001" difference from the next color
If you still have too much clearance with the blue bearings, you would have to grind the crank .010" and use an oversized aftermarket bearing like ACL.
Old Mar 8, 2003 | 10:17 PM
Default Re: b series rod bearing size's (earl)
thanx alot thats what i needed
earl
Engine Machining & Assembly
Jun 8, 2012 09:38 AM
earl
Dec 25, 2003 10:04 PM
UncleBen'sRacing
Mar 8, 2003 10:34 PM
