90-93 integra sway bar in 91 hatch?
My friend put a 91 Integra rear swaybar in his '91 STD. He used the teg lower control arms and then tapped mounting holes for the swaybar itself. Its worked great so far.
You can use the rear as stated about. Can also use the front if you have the brackets from your orginal front but the HF/STD dont have one. The front bar is huge probablly too large and hurt more then help. The rear is 1mm bigger then the SI's for it you need SI or teg rear LCA and SI brackets to mount it to the sub frame..
Stop the Beast
16
Jul 26, 2004 02:00 PM
importboi22
12
Mar 8, 2004 04:14 AM
