usdm bumper rebar used in jdm conversion?
Old Mar 8, 2003 | 12:14 PM
nightrider's Avatar
Default usdm bumper rebar used in jdm conversion?
when doing the jdm front-end conversion, is it possible to use the stronger and thicker usdm bumper rebar? couldn't find anything in the searches.
Old Mar 8, 2003 | 02:09 PM
ITR 2K's Avatar
Default Re: usdm bumper rebar used in jdm conversion? (nightrider)
I know six guys that have done the conversions, and none of them used their usdm rebar. That JDM rebar doesn't look like it'll hold up in any kind of front end collision.
Old Mar 9, 2003 | 12:31 PM
E46M3CB's Avatar
Default Re: usdm bumper rebar used in jdm conversion? (ITR 2K)
yes you can, depending on the bumper... I have the Cwest kit and it first just fine, but you need to trim the styrofoam part...
But in regards to making the USDM Bumper support into a JDM bumper support, just drill out the welds holding the middle bar and remove it, then use the ends and attach a bar into the sides...
Look at the USDM bumper support and you'll understand what I am talking about for the hole... Hope this helps.
Old Mar 9, 2003 | 01:02 PM
VTECPWR's Avatar
Default Re: usdm bumper rebar used in jdm conversion? (serenity)
You can use the USDM bumper support on the JDM OEM bumper. It will take some work but you can do it. Just pull out the handy die grinder whatever other tools you need and go to work.
Old Mar 9, 2003 | 03:05 PM
Chiller20's Avatar
Default Re: usdm bumper rebar used in jdm conversion? (VTECPWR)
Anyone got pics of these bars installed and not installed?
Old Mar 10, 2003 | 10:39 PM
ALLBLINE's Avatar
first off the bat learn how to drive the itr 2nd take it to a bodyshop to do the conversion right so u can blame someone else for ******* up holla
[Modified by LYNNWOOD LEGEND, 8:55 AM 3/11/2003]
Old Mar 11, 2003 | 01:07 AM
tC_Dragon's Avatar
Hey, so what year is ur car? cuz i'm not sure if the bumper supports vary between the 94-97 and 98+. The reason i ask is cuz my roomate is gonna pick up the cwest bumper soon and was wondering. Also, will the usdm bar bolt up to the jdm radiator support? We replaced the ENTIRE front radiator support, not jus the top half like some people are doin lately...
Which way did you do urs serenity??
Old Mar 11, 2003 | 07:55 AM
VTECPWR's Avatar
Default Re: usdm bumper rebar used in jdm conversion? (pdcdragon)
I have a 98. A body shop did the work, but I got the parts from an importer. They blamed each other for the missing rebar (I think the body shop either lost it or used it on another car). I am pretty sure they had the mounting brackets and where just missing the bar. It has been almost 8 months since I had the work done so my memory is a little rusty. But they went to work and made the USDM bar work. I would have ordered a JDM bar from options (they are pretty cheap) but it was already Thursday evening and I had to have the car back Sunday.
Old Mar 11, 2003 | 11:18 AM
GRAVEDIGGER's Avatar
.what LYNNWOOD LEGEND said, atleast you can blame somebody
Old Mar 11, 2003 | 10:35 PM
bcrl's Avatar
Will the Mugen bumper fit for the USDM rebar as well? without doing any modification to fit that in?
Thx!
Old Mar 11, 2003 | 10:41 PM
dj sam's Avatar
got a pic of the car with the cwest front??
im thinking of getting one for mine,, wanna see how it looks
Old Mar 11, 2003 | 10:51 PM
Kicker773's Avatar
Default Re: usdm bumper rebar used in jdm conversion? (dj sam)
the cwest front bumper is really nice, already got the rear one on the dc2, working on getting the front. talked to the body shop and they said the usdm rebar will fit for the jdm conversion, but it all depends on the kind of bumper ur getting. if what serenity says is true, then i'm all game, no need to buy the rebar.
for pics, try this link:
http://members.rogers.com/spoondc2/i...oondc2pic9.jpg
http://members.rogers.com/spoondc2/i...oondc2pic8.jpg
[Modified by Kicker773, 7:53 AM 3/12/2003]
Old Mar 11, 2003 | 11:00 PM
bcrl's Avatar
Do you think Mugen JDM bumper will fit the USDM rebar as well?
except for the C-West one .....?
Thx!
Old Mar 12, 2003 | 12:19 AM
dj sam's Avatar
Default Re: usdm bumper rebar used in jdm conversion? (Kicker773)
damn nice.. there's 2 diff kind of products tho,, the n1 front bumper and tht gymkhana one,, whts the diff really??
im at new zealand and im planning to import the front and rear lip from US soon
Old Mar 12, 2003 | 05:55 AM
97 TYPE-R 312's Avatar
Default Re: usdm bumper rebar used in jdm conversion? (bcrl)
From what I understood in the past, the MUGEN bumper WILL fit the USDM rebar. The JDM Bumper wouldn't (w/o modifications).
-Victor
Old Mar 13, 2003 | 01:01 AM
junk yard sol's Avatar
Default Re: usdm bumper rebar used in jdm conversion? (rp2000Rless)
hey i did my conversion and yes the usdm rebar works if you can get an aftermarket front bumper to go over it then go for it. if not then you will need to cut it .. not much . use your judgement. also yes the usdm rebar will bolt to the jdm rad suport. its the same and finally just cut the damn thing have fun do it yourself if you cut a little to much of the ends or whatever it is ok cause if you hit anything head on the febar is not going to do much to begin with ....
Old Mar 13, 2003 | 01:03 AM
Default Re: usdm bumper rebar used in jdm conversion? (JDMDC2ITR)
i forgot the 94 -97 rebar does not differ from the 98-01 rebar identical
Old Mar 13, 2003 | 01:54 AM
EK MONEY's Avatar
just get the JDM in case of the USDM not fitting..
89civicstd
Nov 26, 2011 10:52 PM
Circuit Star-29
Apr 24, 2007 08:32 AM
da9pwnsu
Nov 1, 2005 03:49 PM
payneth
Oct 14, 2004 10:16 AM
hionvtecxda6
Feb 2, 2004 08:01 AM
