B16a axles
From: I told you to wait in the truck in Texas, United States
Read this:http://www.hasport.com/News/Articles...rt%20Axles.htm
I got my axles from http://driveshaftshop.com/
They offer custom axles that do not require seal removal..
i got custom axles made from http://www.raxles.com
i think they were around $300
perfect fit, and a lifetime warranty
fast service too
fast service too
fast service too
fast service too
wow, lots of replies...
do what the hasport site says..
Axles are dictated by which intermediate shaft you use..
If you use a SIR intermediate shaft, you will have to build custom axles.. If you want an easy way out, get a 90-93 integra intermediate shaft and use 90-93 integra axles... (remove dust seal)
I run a 94 integra Intermediate shaft with 94 gsr axles (non-abs)
Jeff
Jeff
so if i got the whole b16a swap from hmotorsonline and i got axles with the swap i wont be able to use them i have to buy a 90-93 intermediate shaft and axles?
[rant]jesus christ guys. freaking use the search button. this is a easy topic to search, it's been discussed plenty of times. [/rant]
ok, about the hmotorsonline axles, they will work!! and if you get your swap from the integra, guess what, you will get a 90-93 integra axles, and a 90-93 integra intermediate shaft!!! and if you get the one from the crx SIR you will get the SIR AXLES and the SIR INTErmediate shaft. Since this combo never came out in the states you will have to use custom axles (or the ones that come with the swap) or you can get the 90-93 combo from an integra over here in the states. It's really not that comblicated to understand.
90-93 Integra axles and halfshalf fit perfectly with no work.Pep boys sells new axles for about $80 each.There are many different axles that will fit but all are time consuming.The easiest and quickest is the 90-93 integra axles.
TheHatchHog
May 4, 2003 07:54 PM
24hourflipness
31
Apr 29, 2003 08:50 PM
, you will net integra axels for that **** man
