About to Piece Turbo Kit NEED HELP
Heywhats up Im about to buy all my pieces for a turbo for my 99 si with the stock b16. A friend can get me parts for a good price so I will be able to save some money than just buying a kit Now my question is I know all the basic things you need like the turbo, manifold, wastegate, intercooler, blow off valve, piping, dp, intank fuel pump,larger injectors, either hondate or aem ems, but what else should i get I want to run like 7lbs on street and 9-10 at the track or for those "special" times on the street. Do i need a missing link? I am also coing to get a new clutch and flywheel any suggestions. thanks in advance
Also what size injestors shouls I get? And shouls they be staurated or peak and hold? thanks
[Modified by supersi99, 5:05 PM 3/8/2003]
Turbo Kit:
>Turbocharger
>Turbo Manifold
>Downpipe
>Piping
>Intercooler
>Blow Off Valve
>Wastegate (If not internal wastegate turbo)
Fuel System:
>Variable
Electronics & Gauges:
>Turbo Timer
>EGT Gauge
>A/F Ratio Gauge
>Boost Gauge
>Gauge Pod
>2-step colder plugs
Miscellaneous:
>Oil Feed Kit:
- Brass 1/8" NPT Tee Fitting
- 4ft of -4AN hose
- 1ft of -4AN hose
- (4) -4AN straight steel hose ends
- (2) aluminum 1/8" NPT to 4AN fittings
- 90 Degree 1/8" NPT to 4AN fitting
- Steel 1/8" NPT to 4AN fitting
- (2) Earl's 1/8" NPT to -4AN adapter
- 1/8 in. NPT to 1/8 in. BSPT Adapter
>Vacuum hoses
>Silicone couplers
>Oil Drain Flange
>Blow Off Valve Flange
>-10AN Oil Return Line Kit
>Turbine Housing Inlet Gasket
>Turbine Housing Discharge Gasket
>Garrett Oil Drain Gasket
>Wastegate Flange (if necessary)
>Wastegate Gaskets (2) (if necessary)
>1/2" NPT to -10AN adapter
>-10 AN male, steel, natural finish weld fitting
>Exhaust Maniold Gasket
>Oil Pan Gasket
>Turbocharger
>Turbo Manifold
>Downpipe
>Piping
>Intercooler
>Blow Off Valve
Fuel System:
>Variable
>Turbo Timer
>EGT Gauge
>A/F Ratio Gauge
>Boost Gauge
>Gauge Pod
>2-step colder plugs
Miscellaneous:
>Oil Feed Kit:
- 4ft of -4AN hose
- 1ft of -4AN hose
>Vacuum hoses
>Silicone couplers
>Oil Drain Flange
>Oil Pan Gasket
for the fuel system, get RC 440 injectors+walbro 255lph intank fuel pump along with a hondata. Also you might need a FPR for tuning and a fuel pressure gauge.
or go with the DSM 450cc's with an earlier generation honda resistor box and save some cash for your pocket....the DSM's are peak and hold so you need the resistor box...if not RC 440cc's saturated will do......when I spoke to mike he said he liked the SX FPR so I think i might go with that even if it is overkill with the aem fuel rail....my .02. Also maybe a greddy profec b boost controller i don't think i saw that in the list
[Modified by mamaboy, 8:38 PM 3/8/2003]
greddy is simple, but good. I dont know who you heard from that it was bad, but maybe they hooked it up wrong? I have heard nothing but good about greddy profec b and above. I am using apexi avcr.....which is a good controller.
Just get the RC 440's, you dont need a resister box.
1JDMDOMINICAN
Dec 20, 2004 06:43 AM
