Stupid JDM Shift boot...
Old Mar 8, 2003 | 05:34 AM
RTW DC2R's Avatar
Default Stupid JDM Shift boot...
Anyone else have a problem with the JDM shift boot being really "tight"? I know its a dumb question but its valid. Since I had to replace mine I figured Id get something for my car that was JDM y0! Mine is so tizzite that it almost wants to pop back into neutral when I have it in second or forth gear. Maybe because its cold outside? Now I am using a non-itr shift console, but I was told they were the same but maybe they arent. It bolted up just fine and appears to be the same though.
Old Mar 8, 2003 | 05:50 AM
387's Avatar
387
Default Re: Stupid JDM Shift boot... (RTW DC2)
I replace mine twice already. With the red jdm and yellow one. No problem at all.
Old Mar 8, 2003 | 06:07 AM
RTW DC2R's Avatar
Default Re: Stupid JDM Shift boot... (387)
must be the console then
Old Mar 8, 2003 | 06:14 AM
Brian's Avatar
When I had mine installed I noticed it was a lot tighter than the stock one. It is especially noticible in 2nd, 4th, and reverse. I used to hold the shifter in gear so it wouldn't pop out. You could always take it out and stretch it a bit. That is what I ended up doing.
Old Mar 8, 2003 | 06:23 AM
machgo5go's Avatar
I pushed down the opening which has plastic retainer that tighten on the shaft and the boot had lot of slack like USDM oem one. NO problem at all.
Old Mar 8, 2003 | 06:25 AM
BDiddy's Avatar
Default Re: Stupid JDM Shift boot... (machgo5go)
yea if you have the boot pulled all the way up to the top and locked towards the top, then it will be tight. But if its set up like the picture above, I havent had a problem.
Old Mar 8, 2003 | 07:07 AM
Joker's Avatar
Default Re: Stupid JDM Shift boot... (BDiddy)
Mine is also like the photo above. No problems
Old Mar 8, 2003 | 07:26 AM
RTW DC2R's Avatar
Default Re: Stupid JDM Shift boot... (Joker)
aiight...i shall give that a whirl
Old Mar 8, 2003 | 07:34 AM
SurferX's Avatar
My JDM boot was exactly the same size/shape as my stock boot, no different. I don't see how there could have been any problems.
Old Mar 8, 2003 | 08:10 AM
LiKe_WhOa!'s Avatar
Default Re: Stupid JDM Shift boot... (SurferX)
what is the diff btw jdm and usdm?
Old Mar 8, 2003 | 08:12 AM
jdmspoonitr's Avatar
Default Re: Stupid JDM Shift boot... (LiKe_WhOa!)
yup. widen the plastic ring a little by pulling down.
Old Mar 8, 2003 | 08:35 AM
SurferX's Avatar
Pretty red stitches.
Old Mar 8, 2003 | 09:22 AM
nfn15037's Avatar
Default Re: Stupid JDM Shift boot... (jdmspoonitr)
Careful or it will break into 3 pieces...ask me how i know
Old Mar 8, 2003 | 10:02 AM
tC_Dragon's Avatar
Default Re: Stupid JDM Shift boot... (nfn15037)
DOOHHHH!! damn dats gotta suck!
Old Mar 8, 2003 | 10:06 AM
RTW DC2R's Avatar
Default Re: Stupid JDM Shift boot... (pdcdragon)
i got it back on...i just removed that little nubs on the inside of the ring and now it slides down far enough and isnt too tizzite. i nearly just decided to cut off the ring entirely
Old Mar 8, 2003 | 10:08 AM
hungsteR's Avatar
I never had a problem with mine. Maybe you got a defective one? LOL.
Old Mar 8, 2003 | 10:10 AM
Airbag Club's Avatar
you can just shave off those little things that stick out on the bottom of the plastic piece, so that it will slide down the shifter more, or you can just get a short shifter, so that the shift throws will be shorter, so it won't have to go as far.
Old Mar 8, 2003 | 10:21 AM
s2k420's Avatar
Just get a B&M short shifter with energy suspension bushings. Then your shifter will sit lower and you won't have a problem with the JDM shift boot being so tight.
It will be tight for the stock shifter though. I had that problem then i got the B&M.
Old Mar 8, 2003 | 03:41 PM
SiN.DC2R's Avatar
Old Mar 8, 2003 | 03:53 PM
Bbasso's Avatar
Default Re: Stupid JDM Shift boot... (hungsteR)
Defective JDM part, NEVER!
Old Mar 8, 2003 | 03:56 PM
98cwitr's Avatar
Default Re: Stupid JDM Shift boot... (Bbasso)
i just pushed down on the ring as far as i could w/o breaking it. Its tight but not tight enough to cause any problems.
Old Mar 8, 2003 | 06:51 PM
R you serious's Avatar
maybe you got the ctr one, they are different
Old Mar 8, 2003 | 07:38 PM
Leo's Avatar
Leo
Default Re: Stupid JDM Shift boot... (R you serious)
I got the CTR one, without my knowing it. I know now because it has a seam between the back two red stitches. It aggravates the hell out of me.
Old Mar 8, 2003 | 07:42 PM
SpoonEK2's Avatar
Default Re: Stupid JDM Shift boot... (Cyborg Ninja)
It also has a different bracket...
Old Mar 8, 2003 | 08:19 PM
itr-j's Avatar
Default Re: Stupid JDM Shift boot... (SpoonEK2)
not that tight
haah
